Which Bilstein
Old Oct 25, 2024 | 09:54 AM
NCShooter00's Avatar
NCShooter00
Which Bilstein
Last week I replaced the front worn out shocks with Bilstein 4600. I am looking online to find the correct rear 4600 and seem to be finding multiple answers. Does anyone know what the part number is? One that I found on another forum said 24-185455. I was trying to source through Rock Auto and did not see that one there.
Old Oct 25, 2024 | 01:15 PM
Ted722's Avatar
Ted722
Checking the Bilstein catalog, looks like it's 24-185479 for 4x4 and 24-185455 for RWD
4x4
https://cart.bilsteinus.com/shock-24...&DriveType=4WD
RWD
https://cart.bilsteinus.com/shock-24...&DriveType=RWD
Old Oct 25, 2024 | 01:23 PM
NCShooter00
Yup. Just found that & was coming here to reply 185479
Old Oct 26, 2024 | 11:19 AM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Yes, that’s correct I just installed them in July.
Old Oct 26, 2024 | 11:35 AM
NCShooter00
Should have mine Monday. Be glad to have them on. I will prob get the Helwig soon too
Old Oct 28, 2024 | 07:25 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
If your 2WD rear end is 1” to 2” higher than stock, you can use the 4x4 shocks because the mounts are the same on both types of Exs. Front mounts are different.
Old Oct 31, 2024 | 08:06 PM
Pickupmanx2's Avatar
Pickupmanx2
Thanks for this, what is the Bilstein # for the fronts, not sure what mine has but they are terribly stiff, guessing they are the Fab-tech ones that the po put on with the lift...
2000 5.4 2wd - are the fronts on lifted 2wd same as 4wd?
Old Oct 31, 2024 | 08:40 PM
NCShooter00
Confirmed with Bilstein by phone:
Fronts are 24-185462
Rears are 24-185479
I just put the rears on mine today, fronts last week before Redhead box
The ones that were on it were stamped Ford Motorcraft, so original at 168k
Old Nov 1, 2024 | 04:40 PM
Pickupmanx2
Thank you NCShooter!
Rears are 24-185479
Old Nov 1, 2024 | 06:15 PM
Ted722's Avatar
Ted722
i just swapped my originals out this year ~105K miles. Couldn't believe how easy they were to compress. Almost no resistance..all 4 of them. The new one's (KYB's) had A Lot more compression. Really has helped out the ride though.
Old Nov 1, 2024 | 06:21 PM
NCShooter00
Yeah the Motorcraft on mine is could easily compress with one hand. Not the 4600s
DinoB
Nov 28, 2025 10:26 PM
MKrenn
Feb 13, 2025 08:46 PM
rallymini
Feb 18, 2019 04:36 PM
maevans
Apr 12, 2013 09:30 AM
Brandon Bloomquist
6.7L Power Stroke Diesel
Oct 16, 2012 10:57 AM
