Help truck has abnormal bouncing
Old Oct 23, 2024 | 10:39 PM
540milotalon's Avatar
540milotalon
Long story, 1996 Ranger, 2 wheel drive with 5.0 engine, A/T and 8.8 from 1999 Mountaineer.
I assembled truck in 2019-2020. Drove truck approximately 64K and it starting acting really strange when getting in a bumpy area in the road. It would start a "death wobble." Truck has 208K miles.
Truck was originally a 3.0 V-6 so after I found the shocks had went bad on the front I replaced the coil springs to 4.0 coils, new shocks, new leafs on the rear, and upper/lower ball joints and outer tie rod ends.
No noticeable change. After front end alignment I changed the radial arm bushings (driver side noticeably loose looking by this time) and it is a noticeable change.
What do I need to look at? I had replaced the regular shocks on the rear with coil over spring shocks and it became worse, switched back.
All this just started? All bushings
in the rear NEW, the only left on the front to change is the pivet bushings.
16" Cooper E rated Tires have 20K on them.
I AM STUMPED.
Old Oct 23, 2024 | 11:39 PM
Papa Tiger's Avatar
Papa Tiger
Suspension & ball joints, shocks etc.
Old Oct 24, 2024 | 11:08 AM
G2IC_Wraith's Avatar
G2IC_Wraith
Not something that sounds like fun, but I would ask some questions first.
Q: Is the problem reproducible? IE - do you know where you can drive to make it "act up?
If no, that makes it more difficult to know whats doing it.
If yes, then I would ask a friend to drive behind you & if possible, video it so you can see it too.
This would really help to see exactly what is moving around.
Q: What condition are your sway-bars, bushings, & end-links?
Old Oct 24, 2024 | 04:08 PM
540milotalon
All new springs, front and rear. All Four upper and lower ball joints, both outer tie rod ends.
replaced rear shocks, Monroe went bad. Tried coil over shocks but problem was worse.
has standard 4 wheel drive Ranger rear shocks by Gabrielle.
New radius arm bushings. I don't know what else to check.
Old Oct 25, 2024 | 10:08 AM
G2IC_Wraith
None of that answered the question - "Q: What condition are your sway-bars, bushings, & end-links?"
Keyboard diagnostics are difficult to say the least, so all I can offer is suggestions.
I would also suggest you try the friend following to observe / video what is going on.
An interesting thought: Since you have a franken-truck, I am wondering what you did to prep that 8.8" diff swap?
If the geometry isn't right with the shock mounts & sway-bar etc... I don't think any amount of new parts will fix it until the geometry is corrected if this is the issue.
Old Oct 25, 2024 | 05:27 PM
540milotalon
I used the Mountaineer 8.8 rear and shock set up, with the springs on top of tube (instead of underneath like Rangers) I had to use Shackles to bring the truck height back up and set the pinion angle. This was easier for me than cutting off and rewelding the spring pads/shock
mounts. The upper shock mounts were originally front and rear of the diff on the Ranger, I moved the passenger side back and have both upper shock mounts on the frame, above the rear of the differential.
It's basically an Explorer in the rear, on Shackles for about 5-1/2" height.
This setup worked for approximately 60K miles and then wham! Wobble.
Old Oct 25, 2024 | 09:04 PM
nelbur's Avatar
nelbur
What tire pressure are you running? Higher pressure makes things bouncy and has a negative effect on handling. Of course, the main function of shocks is to control bouncing. Make sure you have good ones on the front.
Old Oct 25, 2024 | 10:36 PM
pawpaw's Avatar
pawpaw
Wifes Neon was doing this squirley wobble kind of thing on the same bumpy area road last year, turned out to be steering end links, passenger side was so worn the ball was about to pop out. With the 5.0L extra weight the front end was never designed to deal with, everything is on the suspect list including the steering rack & its mounting bolts,
Good ideas posted for suspects & checking things out. Will be interesting to hear what you find.
Korbin
Dec 16, 2019 03:35 PM
cdf912
Jan 12, 2018 09:13 PM
John Thomas II
Offroad & 4x4
Oct 9, 2005 01:55 AM
Red77F100
Mar 26, 2005 05:16 AM
mwkellner
Dec 18, 2000 10:27 AM
