Do I need a new PCM?
Old Oct 20, 2024 | 03:15 PM
Blastzone's Avatar
Blastzone
I just replaced my IDM due it getting flooded and now my truck runs and drives, but when accelerating going past 1500rpm it starts stuttering. I plugged in my scanner and it cannot communicate with the PCM but can communicate with the other computers. Check power and ground to the PCM and they are good.
It was communicating before the IDM was replaced and that's how I found out the IDM went bad.
The PCM number.
- PTM2 DPC-422
Old Oct 20, 2024 | 03:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If the truck starts and runs, then the PCM is communicating with the IDM. There are only 3 modules in our era trucks. PCM, IDM and VSM or GEM based on the model year.
Did the truck flood or just the IDM?
Old Oct 20, 2024 | 03:30 PM
Blastzone's Avatar
Blastzone
Just the IDM
Old Oct 20, 2024 | 03:36 PM
John in OkieLand's Avatar
John in OkieLand
I would unplug the PCM, and spray the connectors with CRC contact cleaner, you can find it at any box store, auto store...
several different flavors of it
spray, plug / unplug / plug it in / pull and put it back together.
Amazon Amazon
Old Oct 20, 2024 | 03:48 PM
Blastzone's Avatar
Blastzone
Tryied that, didnt seem to work. Still getting the code
Old Oct 20, 2024 | 04:06 PM
Blastzone's Avatar
Blastzone
Just the IDM was flooded
Old Oct 20, 2024 | 05:40 PM
Pikachu's Avatar
Pikachu
Have you checked your fuses?
Old Oct 20, 2024 | 05:45 PM
Blastzone's Avatar
Blastzone
Yes I have checked all my fuses and relays
Old Oct 20, 2024 | 05:57 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What code (specifically, by the DTC number) did you pull... that inspired you to change your IDM?
Old Oct 20, 2024 | 07:30 PM
Blastzone's Avatar
Blastzone
Had no communication to the IDM and it had water inside. At the same time i put new motorcraft ICP, IPR, and cam sensors in.
Old Oct 21, 2024 | 01:08 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
How does the fuel filter look? Any chance of getting fuel pressure when the stuttering starts?
Old Oct 21, 2024 | 08:40 AM
Blastzone's Avatar
Blastzone
It has a new fuel filter and fuel pump, Having no issues starting it.
Old Oct 21, 2024 | 04:55 PM
RA101725's Avatar
RA101725
Banned
Where'd the IDM come from? Might be no good.
Old Oct 21, 2024 | 04:56 PM
Blastzone's Avatar
Blastzone
GB Remanufacturing
Old Oct 21, 2024 | 05:40 PM
udsuth78's Avatar
udsuth78
If you're stuttering and stammering above 1500 rpm then you need to test the fuel pressure. There is a simple method in the tech section explaining what you need and how to do it. You'll want to check the fuel for aeration too. You can do that by catching a sample of fuel from your test rig before installing the gauge. If you get bubbles in your sample then you've got a leak somewhere letting the pump suck air. If you've checked all the fuses with a meter not just visual and they all are good you might try a hard reset on the PCM. It's kinda a long shot but I've gotten lucky and cured weird behavior with it before.
