Another v8 build…
Old Oct 18, 2024 | 08:50 PM
3twinridges's Avatar
3twinridges
Another v8 build…
I bought a block back in 2019 on fordbarn. Guy said it was a good block and it looked ok, but it sat in my basement for a while. I finally took it to the machine shop about a year ago and it’s been in line for a build. It went through cleaning and inspection today and had no cracks other than the typical head bolt deck cracks.
I have everything except pistons and rings and will be taking all the parts down next week to get this project started!!! Can’t decide between a 1CM merc cam or an EAB ford cam (I have both).
JB
Old Oct 18, 2024 | 09:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you buy a bare block or a short block? If you need internals, I have plenty including cranks. I'd like to see them gone.
I don't think there's a lot of seat-of-the-pants difference between the EAB and Merc cams. What intake/carb setup will you use?
Old Oct 18, 2024 | 09:19 PM
3twinridges
It’s a stock build Ross with a 4” crank. I think I have everything for it, I just need to double check tomorrow. I think I might need a pickup oil tube, pickup tube bolts, oil pump bolts, and oil pump idler gear cover bolts.
JB
Bmoodie10
Jun 19, 2018 01:15 PM
RFAgrasshopper
May 15, 2012 10:13 PM
Ford_Six
23
Jun 4, 2010 12:46 PM
Red69
Oct 9, 2007 08:14 PM
crawlfish
Feb 20, 2005 08:24 PM
