Sponsored by: Real Truck
Hub assembly issues
Old Oct 18, 2024 | 07:25 PM
Puresouthurn's Avatar
Puresouthurn
8th Gear
Hub assembly issues
Just put on two new hub assemblies and axle shaft seals installed correctly with the proper tools and both hubs are pretty hard to turn by hand and I've never experienced this before as I've changed many of these and used this same brand of hubs with no issues before I've even added some grease through the sensor holes with no change so has anyone else ever had this happen with new set cause it's a first for me
this is on a 2001 f350 4×4 dually
Old Oct 18, 2024 | 07:47 PM
Pikachu's Avatar
Pikachu
I've always had a fair amount of resistance to turning with new hubs. The bearings have a certain amount of preload and that's what causes it.
Edit: You mean with the wheels off and trying to turn the hub by hand, right?
Old Oct 18, 2024 | 07:58 PM
Puresouthurn
8th Gear
Yes sir with the wheels off
Old Oct 18, 2024 | 08:10 PM
Pikachu's Avatar
Pikachu
Okay, if it was with the wheels on, I'd be concerned.
steff503
Oct 5, 2018 08:48 PM
Mumbly Joe
Sep 9, 2016 02:00 AM
54Hydro
15
Jan 5, 2014 12:06 AM
EJSF350
Mar 22, 2013 12:46 PM
75F350
Jul 22, 2006 02:06 PM
