170 degree operating temperature
Old Oct 18, 2024 | 07:14 PM
bryce12's Avatar
bryce12
8th Gear
My coolant temp has been hovering right around 170 degrees even when on the highway. Is this normal or should I be worried about a thermostat that’s stuck open. Seems to warm up fine in the morning but will not hit 180/190 which seems to be the normal temp.
Old Oct 18, 2024 | 07:17 PM
bryce12's Avatar
bryce12
8th Gear
Also scanned for codes and nothing showed up.
Old Oct 18, 2024 | 09:34 PM
speakerfritz's Avatar
speakerfritz
If coolant temp is always 170, have you noticed any regens….180 is needed for operator commanded regens.
Old Oct 19, 2024 | 01:34 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Sounds like it's thermostat time. Get the Motorcraft part and swap. Won't take long and chances are, it's been revised since the last time it was replaced.
Old Oct 20, 2024 | 08:29 AM
senix's Avatar
senix
mine will run 170 some but comes up with working the motor.
You should see it vary anywhere from say the 170 to as high a 225-230 on occasion.
Old Oct 20, 2024 | 11:16 AM
acdii's Avatar
acdii
If your truck came with the grill blanket, put it on and see if the temps go up. What is the transmission temp? both should mirror each other by a few degrees.
tristan2
2015 - 2020 F150
May 1, 2022 07:11 PM
Subzero68
Jan 26, 2014 11:56 AM
mblanken881
Nov 27, 2010 07:33 PM
gearheadz80
Sep 8, 2006 08:54 AM
The Grinch
May 21, 2003 06:17 AM
