Coolant Temp Indication Problem?
Old May 20, 2003 | 03:39 PM
The Grinch's Avatar
The Grinch
Question Coolant Temp Indication Problem?
On the road, my temp indicator on a 95 PS moves up and down from the "R" to the "M" in the "NORMAL" range, sometimes higher, and back, based on speed and hills. Is this normal or an indication of a thermostat going bad because it is not maintaining a constant temp?
Old May 21, 2003 | 06:17 AM
Quadzilla's Avatar
Quadzilla
The cooling system on these trucks, when operating properly, is very efficient, and my needle doesn't move once warmed up. I'd suspect your thermostat isn't opening properly.
