Bought the wrong truck. Help
Old Oct 19, 2024 | 02:37 AM
  #121
usafakid09's Avatar
usafakid09
Originally Posted by PatrickStapler
Also, if you trade for a ‘25 I believe the ‘25 6.7L SO is the same as a ‘23/‘24 6.7L H.O.
Really? Where is this info located?
Old Oct 19, 2024 | 03:30 AM
  #122
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by CR172
How low can I go without tripping the TPMS or making changes with Forscan?
about 12psi below door sticker #’s on vin plate
Old Oct 19, 2024 | 07:11 AM
  #123
Roadhunter's Avatar
Roadhunter
F450 Ride
Originally Posted by acdii
250, 350, 450, the ride is ALL in the tires. Its that cushion between the pavement and the axle that matters most. Why does an F450 ride so stiff? Steel belted sidewalls from bead to bead and 90 PSI of air pressure to keep the tires on the rim. How do you soften the ride of the F450? Replace the wheels with 20" wheels and put on LT tires with polyester belts and steel tread bands, and run them at 50 PSI. The soft sides soak up the bumps and the only harshness are those bumps that bounce the suspension. Downside, those wheels and tires cost $8,000 or more.
F250/F350, its all in the tire pressures. 350 have higher pressures for the higher GVWR. Lower the pressures, trigger the TPMS< or Forscan the TPMS to a lower trigger value and ride is as good or better than the 250. My DRW now runs 60 in the rear, 70 in the front and frankly, it rides like a caddilac compared to the exact size F450 with the heavier stiff tires. I mean it still rides like a heavy truck, but its comfortable compared to the 450. Tires made a huge difference.
This is my 2nd F450 and the first thing I did on my new one was to swap out the 19.5’s for 20” with 275-65-20 KO2’s. I now have my dream truck! Rides as good or better than my F350 CCSB SRW and will turn circles around it.
My only complaint is the top end governed at 140km/hr.
Old Oct 19, 2024 | 04:32 PM
  #124
acdii's Avatar
acdii
If the one I had was a 20+ with the 10 speed, I might have sprung for new wheels and tires. Problem I have is the style of the aftermarkets, at least the ones I have seen don't look good to me. I think plain Alcoa wheels look nice but the ones with crazy patterns and spiked lug covers, just don't appeal to me.
I do miss the turning, man, that truck was SO easy to park! I'm getting the hang of the new one though, I just have to make adjustments on where to put the truck before backing and remember its NOT the Flex or 450. However I never did get the hang of just pulling the F450 into a space, which means I Still have problems pulling into a space, I usually get the rear fender in the way.
Old Oct 20, 2024 | 11:36 AM
  #125
Joe T's Avatar
Joe T
Forscan is pretty easy.
Set tpms at 57 and run at 53 and air up to 75 when towing?
Old Oct 20, 2024 | 12:15 PM
  #126
RandyinTN's Avatar
RandyinTN
The light is very tiny and basically unnoticeable in the lower right corner of the display. I used to be paranoid about it on my previous truck but its not an issue now.
Old Oct 20, 2024 | 02:19 PM
  #127
Rwhjr's Avatar
Rwhjr
true but for me personally I like it not being on 24/7 because when it does come on I like to know there’s an issue. But that’s just my OCD partly.
so i also prefer to have it functional even if the lights not a big deal
Old Oct 20, 2024 | 03:51 PM
  #128
RandyinTN's Avatar
RandyinTN
It is still functional. And a big positive is if you are low it will display the TP as soon as you start it up. I like knowing what the TP is right off the bat.
Old Oct 20, 2024 | 05:30 PM
  #129
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I disabled my TPMS completely. I don't need that crap annoying me since I run 40-45psi empty in the rear.
Old Oct 20, 2024 | 07:44 PM
  #130
Dmeyer7681's Avatar
Dmeyer7681
I find using cruise control at 65 in tow/ haul mode a good towing experience, the truck picks the right gears and pulls strong, I’m pulling less weight as my trailer is around 8000 lbs but no worries here.
CCLB 7.3 4.30
Old Oct 21, 2024 | 05:42 AM
  #131
Joe T's Avatar
Joe T
I just fixed a tire that was losing about 1/2 lb a day.
Why not adjust your tpms instead of shutting it off.
Also the ride between 50psi and 40psi isnt much different.
MAX4utah
Mar 9, 2024 04:54 PM
jpeterson05
Jul 10, 2017 10:19 AM
judithgap
6.2L V8
20
Mar 18, 2013 10:16 PM
T.Mainus
Dec 13, 2009 08:30 PM
uk_vette
Sep 8, 2007 05:27 AM
