Bought the wrong truck. Help
Old Oct 17, 2024 | 09:22 AM
  #106
dvcr250's Avatar
dvcr250
Originally Posted by rna352
I wouldn't mind paying extra for the diesel, but the reason I went with gas was I wanted the lightest weight Super Duty that fit my needs. That right there is another actual difference between the two, and a benefit for me, even if you weren't aware of it until just now.
What do you specifically need the lightest truck for?
Old Oct 17, 2024 | 09:24 AM
  #107
Hutch350's Avatar
Hutch350
Originally Posted by BROWN DOG KTM
Well said
XLT is all you need.
Six7 for towing.
Period = End of Story
Look at all these fancy pants over here with the XLT's
Old Oct 17, 2024 | 10:11 AM
  #108
rna352's Avatar
rna352
Better weight distribution handles better. Less likely to sink in and get stuck on soft ground. Easier to recover if it does happen.
Plus my 2 post lift is only rated to 7K lbs.
Old Oct 17, 2024 | 10:20 AM
  #109
acdii's Avatar
acdii
Originally Posted by Joe T
The dually pickup has the same frame design. Having owned a 2wd 6.7 2020 F350 dually I will say they tow better but its not substantially better than my f250 at 15k conventional or 17k gooseneck. Getting over that and the drw has much more margin, but rides like absolute garbage truck.
My DRW rides great, better than the SRW 2012 I had. It is one SMOOTH truck.
Old Oct 17, 2024 | 12:52 PM
  #110
OBS460's Avatar
OBS460
6,200lbs of payload.
Old Oct 17, 2024 | 01:18 PM
  #111
DPelletier's Avatar
DPelletier
Ditto. Ride is subjective and people have different expectations but I have four SRW's and two DRW's and I don't notice much of a difference in ride between the two....people complaining probably run the air pressure much higher than they need to on the dually. The DRW is overkill on smaller trailers but on some loads (truck campers, job site trailers, larger bumper pulls and 5th wheels), I find them much more stable and reassuring.
Dave
Old Oct 17, 2024 | 07:59 PM
  #112
BROWN DOG KTM's Avatar
BROWN DOG KTM
6200lbs in what configuration ?
pix of the yellow sticker ?
Old Oct 17, 2024 | 08:06 PM
  #113
BROWN DOG KTM
Originally Posted by DPelletier
Ditto. Ride is subjective and people have different expectations .... people complaining probably run the air pressure much higher …
Dave
so many ppl now are in Super Dutys that’s came from SUV & little cars : this is most of the complainers.
these newer SD trucks rides WAY BETTER than ANY older compatible truck : period.
Old Oct 17, 2024 | 08:53 PM
  #114
BPTS's Avatar
BPTS
Amen.
Did you ever drive a 79 F350 dually that the 3 longest leaf springs were doubled on? That’s how we used to have the spring packs built for tow trucks. They would haul anything all day with negligible squat.
You would find loose fillings and weak bladders quickly though.
Hope you find the right truck OP.
Old Oct 17, 2024 | 09:19 PM
  #115
OBS460's Avatar
OBS460
CCLB DRW 4x4 XLT Premium with a 7.3
I could park my OBS RCLB on the back and still be under payload.
Old Oct 18, 2024 | 02:27 AM
  #116
BROWN DOG KTM
CCLB DRW 4x4 XLT Premium with a 7.3 …
Oh it’s DRW. THAT explains it
Sweet Pckg
My 2016 Dually has way more payload than my 2019 F350 SRW. Both are Six7 btw
Old Oct 18, 2024 | 02:45 AM
  #117
BROWN DOG KTM
The dually pickup has the same frame design. …
the drw has much more margin, but rides like absolute garbage truck .
Dually Has a boxed frame like the SRW & rides very good.
The cab & chassis DRW has a C Chanel strait rail frame with shorter stiffer leafs & way more leafs making them ride absolutely horrible when unloaded.
BUT they’ll haul most anything that’ll fit
Old Oct 18, 2024 | 09:07 PM
  #118
CR172's Avatar
CR172
Managed to find a CPO F350 King Ranch, 6.7L SO, 6.75 bed, 5K miles in Antimatter blue w/bronze two tone. New to both diesels and SD's but the drive home from the dealer was very nice. Might be a touch stiffer in the rear but then it should be. Very nice truck and I am happy.
Old Oct 18, 2024 | 10:47 PM
  #119
OBS460's Avatar
OBS460
Lower your tire pressure and then see how it rides.
Old Oct 19, 2024 | 12:12 AM
  #120
CR172's Avatar
CR172
How low can I go without tripping the TPMS or making changes with Forscan?
