Bought the wrong truck. Help
Old Oct 15, 2024 | 08:50 AM
  #31
CBEllis's Avatar
CBEllis
Originally Posted by CR172
Bought a 2024 F250 Ultimate Lariat CCAB 6.75 box, 7.3L gasser to pull our 13K GVWR 5er and boy did this dog ever struggle in the hills of New Mexico, Wa, Ut, etc. Screaming up 5% grades at 4K rpm in 4th gear is a bit nerve racking while people are buzzing past pulling much larger trailers. We put less than 7K miles on this truck and are looking to trade. We will be taking a big hit to the wallet so I don't want to make the same mistake twice. The truck also sagged a bit more than I would like. SO...... Do we move to a 350 with the HO diesel, stay with a 250 w/ the diesel option and add air bags, 3.31 or 3.55 gears? And HO vs SO?
TIA
Bill
Hey - if you can afford it, make the move. I'd go with an F350 Standard Output 6.7L Diesel. You don't want to fail too many times...it's expensive and in-general, people should learn from their mistakes. But, I learned early on in life, that when you fail, fail fast, admit the mistake, and move on trying not to make the same mistake twice. I got rid of my 2017 6.7L and regretted it quickly. Moved back into a 2023 as soon as I could. The new diesels, 2023-2025 are well built and efficient as daily drivers. The emissions systems function much better. You'll be happy and it'll tow more confidently. Just do it.
Old Oct 15, 2024 | 09:27 AM
  #32
Joe T's Avatar
Joe T
If you go this route get a long bed too.
Old Oct 15, 2024 | 09:36 AM
  #33
PatrickStapler's Avatar
PatrickStapler
Agreed. I have always hated (so I thought) long bed trucks. My '23 is a long bed and I'll probably never own another short bed truck. Even though the difference in length is less than 2', the ride in the long bed is so much better and the extra bed capacity is a huge bonus.
Old Oct 15, 2024 | 09:44 AM
  #34
CR172's Avatar
CR172
No long bed, no moon/sun roof and no red
Old Oct 15, 2024 | 10:50 AM
  #35
traveldawg's Avatar
traveldawg
fwiw.....
Ride:
  • I don't think the diesel F-350 rides any different unloaded than the 7.3. I have the 6.7, close friend has the 7.3. Mine is a LB, his is a SB.
  • He only drives in the east, so not steep grades relative to the west. I drive in the west a lot. His truck lugs and shifts on the slightest grades and then revs up (even the overpasses in FL) so he keeps 10th locked out when towing and complains about it slipping to 7th from 9th skipping 8th gear on hills. (I think he got the wrong rear end, he would have liked the 3.73 but he thought he'd get better fuel milage with the 3.55s)). My truck tows in 10th without issue although I lock out 10th in the west a lot of times with the 3.55s..
  • After many trips locally in his truck I can't say the ride is any different unloaded than in my truck unloaded. No comparison loaded as I haven't ridden in his truck when he is towing. He does always have his 5th wheel hitch in his, I run with a goose ball so he has a bit more weight. We both have about 30 gallon aux tanks. So it is pretty even comparison I think, Again - no significant ride difference that I can see.
  • My truck doesn't sag, but my 3200 lb pin weight on the camper lowers the rear at least 2 inches. I have AirLift bags for that and they absolutely improve my ride (along with my Reese Goosenehith with its air bag).
  • When I had a standard hitch on my SBs I also had air ride and the ride was OK. I like the goose ball better tho.When pulling, I have no issues - anywhere. Up hill is where I make better time than the huge motorhomes, semis, and gas powered trucks. I'm not trying to set any speed records, it just goes up mountain grades effortlessly (I have the SO output).
  • Going down mountain grades is not a problem with the diesel. If anything, it seem a bit aggressive some times. I have no experience with a gas engine (nor do I want that experience).
LB versus SB:
  • I had 3 SB trucks since 2020 and now have a '22 LB. I went with a LB because I got tired of the weight of a slider hitch when having to take it in and out of the truck and with the SB I was too close to my weight limit on the truck. So the LB got me at least another 500 lbs of carrying capacity and I lost about 200 lbs of slider hitch weight with my gooseneck ball hitch. My campers weights in at just about 15k loaded.
  • Turning and parking is, of course, a bit more than the SB. But after all is said and done it hasn't mattered much. We do have to more selective when choosing parking spots, but it hasn't really been an issue (when using a daily driver or when traveling while towing).
  • I think the ride is a bit better in the LB when empty. This is very subjective tho. ymmv
  • With my Aux fuel tank and the gooseneck I have a LOT more room in the bed when towing such that a small generator and gas can easily fit still leaving room for other stuff if we had the need.
  • I don't miss the SB.
  • Garage parking at home could be an issue for many tho with the longer bed truck. I don't have that issue.
  • I can make a 90 degree turn with the camper if I want. I could do that with the slider hitch too. I firmly believe anyone in a SB needs a slider in many situations (lots of folks would say no).
Hopefully you find some of this input useful.
Old Oct 15, 2024 | 11:19 AM
  #36
DPelletier's Avatar
DPelletier
TIA
Bill
My 2 cents;
- definitely the F350, a 250 is payload challenged for a 5th wheel, especially in a diesel. They don't ride significantly different IMO; wheelbase and tire pressures make much more difference.
- with the 6.7/10spd, gears don't matter much - I'd go with the 3.55's if possible since I routinely lock out 10th with those gears when towing anyhow.
- HO vs. SO.....well the SO has more than enough power though more is always nice....there have been a few people with issues with the HO in recent posts. At your weight, it's a want, nowhere near a need so it depends on your budget.
Another thought is I'd definitely go with a LB if I was pulling a 5th wheel - no sliding hitches or worries about hitting the cab, better stability and ride. If you get the CC LB, you get the 48 gallon tank (vs. 34 galls) which gives you better range.
Good luck
Dave
Old Oct 15, 2024 | 11:21 AM
  #37
Bugzilla46310's Avatar
Bugzilla46310
My 2023 F350 CCLB is the best riding SD I have owned. Also had a 2000 SCLB and a 2016 CCSB, all gassers.
Old Oct 15, 2024 | 11:32 AM
  #38
CR172's Avatar
CR172
Originally Posted by traveldawg
fwiw.....
Ride:
LB versus SB:
We do have a PullRite SuperGlide hitch and so far no complaints. We had to make some pretty tight turns and all was good
Old Oct 15, 2024 | 11:37 AM
  #39
acadianbob's Avatar
acadianbob
Thank you. I have towed many trailers many times and you are correct. I/we did not enjoy all the downshifting and hi revving of the engine. A more relaxed subdued easy climb will suite us better.. No one answered the question about ride quality. The 250 we have is nice. Will the 350 be a harsher ride?
I think you should be more concerned about how the truck handles your trailer than how it rides. Definitely go for the 350.
Was that helpful or should I just be quiet?
Old Oct 15, 2024 | 12:56 PM
  #40
CR172's Avatar
CR172
This will also be my dd and I don't want to drive a dump truck.
Old Oct 15, 2024 | 12:59 PM
  #41
NeverboughtanFseries's Avatar
TIA
Bill
I do 13k at 1000' elevation steady 60- 65mph at 6% grade quite easily under 4k (36-4200 in the video posted) in my hood, but I was smart enough to spec 4.3 rear on my gasser.
4k ain't screaming btw.
https://youtube.com/shorts/gnpsPt1V_Hk?si=9BeyO1YTk0BWXVdl
Old Oct 15, 2024 | 01:43 PM
  #42
RandyinTN's Avatar
RandyinTN
Then buy a 350 and lower the TP to 55 in front and 45 in rear when not towing.
We learn from our mistakes. There is always an active thread concerning someone who bought a 250, incorrect gears, or a gasser and regretted it.
Old Oct 15, 2024 | 02:18 PM
  #43
scottz99's Avatar
scottz99
Veteran: Navy
Did you remember to put the Godzilla Stickers on? Performance comparison Sorry, couldn't resist.
With only 7k, perhaps you could trade for a slightly used 6.7. If you can take the hit, a new one. Don't beat yourself up too much; I just sold a new tractor at substantial loss because I didn't go big enough.
Your decision; all I can offer is you won't regret going diesel; pulls my 16k 5th wheel up the hills without breaking a sweat.
Old Oct 15, 2024 | 02:19 PM
  #44
acdii's Avatar
acdii
Or an F450, fall in love with the turning radius, only to fall out due to the crappy ride and poor fuel economy as a DD. If only I could have kept my F150 AND get the F450 for just towing the 5th wheel.
Old Oct 15, 2024 | 02:26 PM
  #45
DPelletier's Avatar
DPelletier
An F250 and F350 are 99% the same truck; in some trims and with some options, it can be 100%. Ride quality is not a reason to go with an F250 over an F350 IMO; as I said before, wheelbase, tires and tire pressures will all make much more difference than the rear springs/overloads on a 350 will. Diesel, camper package, plow package, tow package all determine which springs your truck gets whether it's a 250 or 350. Neither is a "dump truck". You have another chance to get the right truck now that you've decided to bite the bullet and go diesel; I'd definitely go with the 350 this time and even if you couldn't live with the miniscule difference in empty ride, It's alot easier to add airbags, Bilstein shocks or even remove overloads/change the spring pack than it is to add to your GVWR/Payload....
2 cents,
Dave
