No start problem
Old Oct 13, 2024 | 05:48 PM
falltome's Avatar
falltome
Trailering
No start problem
My truck will Initially start andruns great. However, after a couple of stops, it won’t start. If I leave it set for a while, I can restart it. I change the PCM with a new one from full force diesel. The truck started up and ran with no problem. I parked it and did not start again just like it did before.
Any ideas I'm stumped.
Old Oct 13, 2024 | 06:17 PM
Pikachu's Avatar
Pikachu
No restart when hot is usually a symptom of low ICP caused by (in no particular order) leaking injector o-rings, faulty IPR valve, failing HPOP. What made you decide to replace the PCM?
Old Oct 13, 2024 | 06:29 PM
falltome's Avatar
falltome
Trailering
The scan had the code for it. It also showed that a power surge had happened.
Old Oct 13, 2024 | 07:52 PM
John in OkieLand's Avatar
John in OkieLand
I would have cleared all codes, and started over again.
not much can kill the PCM normally.
High Voltages ( alternators that run amok can do this )
Shorts on wires that should not have a short.
Old Oct 14, 2024 | 05:49 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Get some Can Spray Air Duster... spray that cold air on IPR and see if it will start after that. Or pour ice water on it. Have read previous stories of people doing that to find an overheated IPR
Old Oct 14, 2024 | 10:27 AM
falltome's Avatar
falltome
Trailering
I will try that today.
Old Oct 17, 2024 | 10:32 AM
falltome's Avatar
falltome
Trailering
Cooling the IPR worked. Thank you for your help.
Old Oct 17, 2024 | 12:40 PM
RacinJasonWV's Avatar
RacinJasonWV
Only purchase a motorcraft IPR (or rebuild kit) from a very reputable source like Riffraff, CCN Fab, Ford dealer. Amazon and eBay are full of convincing fakes.
Old Oct 17, 2024 | 02:47 PM
Brother Les's Avatar
Brother Les
subscribing...........
cleaning and rebuilding IPR looks very simple.
Old Oct 20, 2024 | 12:05 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Problem with rebuild kits is they do not include the electric solenoid. That is the part that fails when hot. So it's new IPR time.
As said above only buy Motorcraft, and only from trusted sources. Plenty of fakes out there.
tlt64
Nov 12, 2020 05:13 PM
JOHN2001
May 12, 2011 05:55 PM
JumpinJoe
Apr 17, 2009 06:22 PM
