F250 issues
Old Sep 27, 2024 | 10:01 PM
Durk978's Avatar
Durk978
Trailering
F250 issues
Hello all. I have a F250 7.3 lariat ext. long bed. So problems have been popping up roughly in the past week. Problem one is my engine has started knocking after roughly a 40 minutes drive. I lose power and now my fuel pump on the rail whines. I believe it is the fuel pump what are your thoughts. I had injectors done last year along with the fuel pump. I have read in another forum that changing the fuel pumped stopped their knock/loss of power problem, I wonder if I have the same issue. Has ran like a champ for the past year. All the problems started after I got fuel from speedway and adding hotshots everyday additive. TIA
Old Sep 28, 2024 | 07:37 AM
Pikachu's Avatar
Pikachu
Maybe a mod can merge this with your other thread: https://www.ford-trucks.com/forums/1...uel-issue.html
Old Sep 28, 2024 | 08:58 AM
bwguardian's Avatar
bwguardian
Have the fuel filter socks in the tank been dealt with?
Old Sep 28, 2024 | 09:05 AM
Durk978's Avatar
Durk978
Trailering
no they haven’t been dealt with.
Old Oct 18, 2024 | 04:06 PM
Hot pocket's Avatar
Hot pocket
If i were you i would start with the simplest explanation first. Probably a clog in your fuel pickup screen or your little screen filters in the pickup assembly.
I would drop the tank and clean those out, and maybe look at the filter in the fuel bowl.
The injectors on these trucks don't like to be starved of fuel. It will run weird with low fuel pressure.
Old Oct 20, 2024 | 12:51 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I second the motion to check fuel pressure.
And if you plan on keeping the truck spend the coin and install a dedicated fuel pressure gauge.
Durk978
Sep 28, 2024 05:09 PM
cmb456
Apr 16, 2024 03:21 PM
TXRangers024
Jul 1, 2013 09:07 PM
clwoodall_76
Dec 4, 2009 10:11 AM
rondawgg1118
Feb 11, 2007 09:30 PM
