Hello all. I would like to change out my old Diff .Can someone tell me what Diff will fit my truck with very little modifcations . So what I am saying simple simple simple Oh i have a 1950 m68 or a f3 truck I understand it is 54 inches back plate to back plate I am useing the truck as a daily driver and i would like to have drum brake on the back there must be a car or truck Diff that will work. Thank you
I used a diff from a 71 F250 with 3.73 gears in my 48 F3. Sure beats the 4.86 gears. Wheel.spacing is right . Spring perches right.Was able to use the park cables with a little rework.
Joe
Reason: Puncuation
Welcome to the forum! Ford trucks from 1948 to 1972 used the same rear axle width and spring perch location. The Dana 60 axle from a 51-72 F250 would be pretty much a direct bolt in and the most simple swap out there. The newer the axle, the more likely it will have a more favorable, higher ratio for more comfortable driving, especially on the highway. It will have your same 8 lug pattern and accept 16" one piece wheels. The early ones didn't have a parking brake included and used a trans mounted brake instead. I'm not sure what year they put the park brake back into the axle, so be sure you get one new enough to have that feature.
I used a Dana 60 from a 1972 F250 in my 52 F3. I have the driveline parking brake so I didn't need the parking brake at the drums. I just removed the un necessary pieces. Some of the swaps need a conversion U-joint. Mine did not.
I had to adapt the brake line. Easy to do with an adapter fitting.
I had to shorten the drive shaft a bit.
It will pretty much bolt in but the pinion angle will be off.
I'm going to try to copy links from my swap posts. https://www.ford-trucks.com/forums/1...l#post15755535
1967 and earlier Ford Dana 60s came standard with 4.56:1 ratios, not a huge improvement from your 4.86:1 ratio. From 68 on, the standard 4x4 ratio was 4.11:1. Best bet is 68 and later 2wd Dana 60. Don’t know much about the 2wd ratios, but most likely in the 3s.
The rear end in my 56 flatbed has tag on the housing that says 2.90.
I can run down the open highway at 65 mph at 2100 rpms.
I would love to know what kind of Ford vehicle that rear was originally in ?
BT
We'll need more information to go by to help identify your axle. Is there any other info on the tag besides 2.90? Do you know what type of rear end it is? (9", Dana 44, etc?)
Im in the process of redoing the wood deck on the flatbed but I’m away this week in Pa.
So I’ll be able to get some good pictures of the rear housing.
thanks
BT
