Cps hall effect
Old Oct 3, 2024 | 03:43 PM
Stevenm95's Avatar
Stevenm95
Cps hall effect
I'm chasing a issue of a 30-50 rpm flucuation at idle and driving. I've changed the IPR and cps with one that came with the truck when I bought it. I did a cylinder contribution test first got cylinder 2 then says pass. I tried reading the hall effect of the CPS but all I got were solid lines.( see pic below.) Am I doing something wrong? Does it not show with it being a 97? Obviously my cam sensor isn't totally bad if it is bad, because truck starts up and runs everyday. Icp has no oil in connector. Isn't hard to start or smoky or anything just the idle flucuation pisses me off
Old Oct 3, 2024 | 04:22 PM
97-psd's Avatar
97-psd
Probably start with data logging the truck and see if you notice a fluctuation in duty cycle or oil pressure
Old Oct 3, 2024 | 07:53 PM
z31freakify's Avatar
z31freakify
In my case idle fluctuation was cure with a brand new set of injectorss not reman but new AC code injectors (160/0)
Old Oct 3, 2024 | 08:15 PM
Stevenm95's Avatar
Stevenm95
that's what I'm thinking may fix mine
Old Oct 4, 2024 | 10:10 AM
knottyrope's Avatar
knottyrope
Mine fluctuated a lot until I ran a few tanks with 2qts of ATF added
There are a few reasons it can happen and not all are easy to diagnose
Old Oct 4, 2024 | 11:26 AM
Stevenm95's Avatar
Stevenm95
funny you say that I just added atf the other day hoping it was stiction.
Old Oct 4, 2024 | 12:11 PM
knottyrope's Avatar
knottyrope
It cleans the injectors internally
Stiction on a 7.3 is usually about the engine oil not allowing the injector to fire when armature clearance is reduced from wear
Old Oct 4, 2024 | 05:53 PM
Stevenm95's Avatar
Stevenm95
my bad your right. Whatever is causing this is pushing me to the point I'm about to sell it. Some times it will idle with a little lope then some times it a few rough lopes. Between that and needing a u joint in my front axel which probably partially causing bad pulsating vibration at 70-80mph
grec-o-face
Nov 13, 2012 01:58 PM
Gruntface
Apr 26, 2012 08:28 AM
ghig1967
28
Nov 5, 2010 03:57 PM
sowaxeman
Aug 16, 2008 09:38 PM
2 stroke man
Nov 24, 2007 05:05 PM
