Grey CPS /Purple O-ring
Old Oct 28, 2010 | 03:28 PM
ghig1967's Avatar
ghig1967
After doing some reading, I decided to try the IH CPS that was dark grey with the purple o-ring. I tried doing a before/after video of how the engine ran with both.. But due to technical difficulties ( or stupidity.. however you wanna look at it) I didn't hit the record button for the "before" segment..
Anyhow.. It definitely smoothed out my engine some.. at idle & using my 1200 rpm idle in my DP Tuner. I'll report back how it runs when I get a chance to go for a ride later.. but so far, it seems to be an improvement over the lite gray installed in the recall .
Old Oct 28, 2010 | 06:03 PM
cj45lc's Avatar
cj45lc
That's the one I'm using, def runs better than the gray POS ford recall one
Old Oct 28, 2010 | 06:43 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I recently did this to both my trucks also.
I checked Rotational Velocities pre and post and found that #3 and #8 readings returned to normal with the International CPS. On 1 truck, all cylinders except #2 now read 0% (#2 averages about .5%-.7%). On the other truck, #8 still reads about 1.2% but I haven't installed my FRx yet on that one....I will do that this weekend and see if there is any difference.
Old Oct 28, 2010 | 09:19 PM
ghig1967's Avatar
ghig1967
Thats good to hear. I wish I had the capabilities to do those kind of tests. Hopefully someday soon I'll get the AE. I do know it definitely idled smoother & when I used the 1200 hi idle I always noticed a hiccup & with the new CPS, it was a lot smoother. Maybe its just me, but it seemed to start quicker than it did on the lite gray CPS.
Old Oct 29, 2010 | 09:29 AM
Trucky2's Avatar
Trucky2
How much was that sensor? I just paid $26 at the Ford dealer for the regular one. Was planning on putting it on during lunch today after another no-start last night...
Old Oct 29, 2010 | 09:55 AM
cj45lc's Avatar
cj45lc
It was $27 @ International
Old Oct 29, 2010 | 10:11 AM
schlepprock250's Avatar
schlepprock250
I asked this in another post but thought I would ask again.I'm running a CPS from International that i put in ~three years ago,it has always run smooth without any issues at all,is the"new" CPS from International supposed to be better than the"old" one from international.
Old Oct 29, 2010 | 10:21 AM
cj45lc's Avatar
cj45lc
I really don't know, all i do know is that when i was @ the International dealer the guy told me this was the latest greatest. I told him I was replacing the gray Ford recall, he said yea a lot of guys were doing the same.
Old Oct 29, 2010 | 11:07 AM
SpringerPop's Avatar
SpringerPop
Saaaaay! Could this be a "shell game" scam???
Pop
Old Oct 29, 2010 | 06:49 PM
ghig1967's Avatar
ghig1967
I paid $24 plus shipping..
Pop
I don't know.. but it really made my truck idle & start better than the lite gray one from the recall
Old Oct 29, 2010 | 07:00 PM
cj45lc's Avatar
cj45lc
Pop
That I don't know Pop. The way things are now days who could say. At least I've got 2 of the shells covered, does seem to start quicker & idle better but w/o a scan no concrete evidence.
Old Oct 29, 2010 | 09:12 PM
creich68's Avatar
creich68
I ordered one from Ed this past May. I put it in just to see what happened. I wasn't sure if there was a difference or not between that cps or the grey cps currently in my truck. I ended up re-installing the grey cps just so I knew i had a functioning spare cps in the glovebox. Maybe if I get ambitious this weekend i'll re-install the international cps to see how it does when it's cold out.
Old Oct 29, 2010 | 09:23 PM
JockD's Avatar
JockD
I have been running the latest Ford OBS sensor for almost two years without any problems. As best I can tell, the main difference between the two is that the OBS unit is a darker grey and has tin-plated contacts. I suspect that the "working end" is enough different that it works better than the later unit.
I used dielectric grease on the pins when I assembled it, and have had no problems with corrosion. I have a smooth idle and not other issues.
I am completely stock, except for a Walker BTM muffler, HPX, high pressure fuel bypass spring, and Dino CCK. No tuner.
Old Oct 29, 2010 | 09:37 PM
PaysonPSD's Avatar
PaysonPSD
On the left is the recall cps. Made in Mexico On the right the latest from FORD. I'm sure it is identical to the INTL.
Old Nov 3, 2010 | 08:20 PM
Waynenap's Avatar
Waynenap
You mentioned $27 plus shipping. Where can a person order one of these. I don't have a international dealer anywhere near me.
Thanks!
