I was going through the shop and found some things I think someone on here might be able to put to good use. I do have the original 3 speed transmission as well, just didn't snag a picture. I don't know the value very well, but if you're interested, please, by all means send me a note with a fair offer. I'm more interested in seeing these items get used than get top dollar.
Thanks!
48 - 52 LMC F-1 bed panel F-2 Radiator (Left) 47 Super Deluxe Radiator (Right) Mater's Motor! It's been out of the truck since 1973 All accessories and parts will come with the motor, starter, everything. Front view
49 F-2 Steering gearbox, straight from Mater himself! - Removed from list
Mater's heater box - SOLD
Reason: Sold Heater Box
May be a player on the Magic Air heater . Are all the fins present on bottom & L side ? Is the core good ? 2 important factors . Thanks ,Denny koda06@bellsouth.net
Hi Denny, All I can honestly tell you about the air box is that it looks to have never been tampered with, and the truck had 79000 miles on it when I got it. It came from Minnesota, so I imagine it worked for the old farmer up until he parked it in 1973. also, I didn't see any evidence of coolant leaks on the unit or in the cab when I pulled it, but again, I honestly don't know, just passing along what I think its condition is. If you PM me, I'll send you my cell number if you're interested.
Hey Anthony,
Cant remember from your built if you kept the F2 bed on yours or not...... Is that "bed front" (don't know technical term) for an F2 express bed, or standard F1 bed. If for an F2, I would be interested. Easier than trying to patch my existing up.
Hey Anthony,
Thanks,
Andy
Hi Andy,
I did keep the F-2 bed on mine, I bought this F-1 unit thinking it was the same size, but it is quite a bit shorter, but could be modified. I decided to patch my original. You will run into the same issue having to section it to work for you. I hate to see any of this stuff go to waste.
Do you know what the engine is? And do you have the heads and head bolts?
It's definitely the original 239 V8 from the truck, I do have the heads, flywheel and a few other accessories. Head bolts I think I also have as well, but I got the motor with the heads removed.
1. 239 V8 flat head engine
2. Manual gearbox
3. Radiators
4. brand new Front F-1 bed panel
I'd really love to see this stuff get used. I promise it's not about the money, or lack there-of, I'd drive to wherever the engine goes to hear it run. I have a strange bond to this truck and to hear that motor run again would be special.
