Speed limiter???
Old Oct 3, 2024 | 10:52 PM
user 19972309843's Avatar
user 19972309843
I'm guessing the driveshaft limits come down to force factors with moving this much weight??
Old Oct 4, 2024 | 04:44 AM
Sport45's Avatar
Sport45
There are many driveshaft critical speed calculators out there if you search.
Here’s one from Spicer. https://spicerparts.com/en-emea/calc...rpm-calculator
For a two piece driveshaft I don’t know if you’d run a separate calculation for each or if it has to be looked at as a combined unit. Of course any slop in the carrier bearing could change things considerably…
Old Oct 4, 2024 | 05:09 AM
user 19972309843
So, essentially, physics is ****ing things up again?
Old Oct 4, 2024 | 06:28 AM
acadianbob's Avatar
acadianbob
You could just back off for a few seconds . . . . .
Old Oct 4, 2024 | 07:02 AM
Joe T's Avatar
Joe T
Someone wanted to “swang” in a V6 Camaro recently and ALMOST clipped me. So I ran him off the road a short distance later. He realized I give 2 cares about my rear fender/bumper (no contact made).
I noticed at around 120, maybe 125-130, quick math via RPM the driveline does make a weird noise. I backed off there. I routinely run around 100 in the left lane when traffic is moving that fast as well without issue but any much faster for long distances and you can tell there is some harmonics no bueno.
CCSB 6.7 6 speed 3.55 with 35.1” tires. Do the math. But I wouldn’t suggest sustaining over 100 long distances. You can do the conversion on your driveshaft speed using my math. My speedometer isn’t recalibrated.
Its more the driveline than the tires as mentioned and in my opinion as well. Oh yeah forgot to mention I don’t have a speed limiter.
Old Oct 4, 2024 | 10:23 AM
user 19972309843
As I already mentioned it's not really about the situation I was in. That was just for context for how I found out about the speed limiter. But no **** banking off and letting an idiot start doing that in front of me with the next couple vehicles a 100 yards up for an unknown amount of time. I don't need a ******* in front of me that may cause an accident I end up involved in. I'd much rather be in control of what variables I can be in control of.
Old Oct 4, 2024 | 12:48 PM
Sport45's Avatar
Sport45
But he didn’t cause an accident on his way up to you and apparently didn’t cause an accident after you goosed it to get away from your perceived danger. As others have said if you had backed off a mph or two he would have continued on his merry way. He was probably using adaptive cruise and just locked onto your tailgate for a bit.
Now you can remove your speed limiter if you wish, I really don’t care. But think about it, you are taking a chance playing with unknown variables and possibly risking others on the road. This whole mess started because you were concerned about someone else you judged a possible danger to others.
Old Oct 4, 2024 | 01:11 PM
user 19972309843
I think you're missing my point here. I'm saying he could've caused an accident. Regardless of the fact that he didn't I didn't want that possible hazard in front of me. And as he was driving in my blind spot in the lane to the left of me with no vehicles in front of him I highly doubt it was adaptive cruise control. There was no vehicle to adapt to and adaptive cruise control wouldn't let him follow that close if it was messing up and adapting to me.
How exactly would I be putting others at risk by getting away from someone on a mostly empty desert highway? I know I didn't mention that it was a desert highway but now you know that.
Old Oct 4, 2024 | 04:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The way that could happen is if a tire blows or the driveshaft disintegrates due to the excess speed, causing you to lose control and hit someone else.
Old Oct 4, 2024 | 05:07 PM
user 19972309843
Ok fair response. Though I highly doubt that would happen if it was for a short period of time. Sure if i was pushing the limits everyday that would be an issue, but to get away from the occasional idiot, i doubt it.
Old Oct 5, 2024 | 03:56 AM
Sport45's Avatar
Sport45
The thing is, you’re basing your decisions on what you “think” might happen or not. As an engineer I learned early in my career that if you don’t “know” it’s right you have to consider it’s wrong. That’s why you have to calculate things like critical driveshaft speeds. The engineers at Ford set the limiter as they did for a reason. Unless you know the reason or the safety factors used in calculating the limit you’re just guessing. Again, I don’t care what you do to your truck. The odds of it having any affect on me or mine is infinitesimally small.
I can say though that critical speeds of rotating machinery are called that for a reason. You have to push through or back out of critical speeds very quickly. Seconds at these speeds can be disastrous.
Old Oct 5, 2024 | 09:38 AM
Summers22's Avatar
Summers22
When I had my 17 F150 5.0 and tuned with Oz, S&B intake and Borla exhaust, a buddy in a Chevy Silverado decided to pass me at about 120 and he had literal smoke coming off his tires.....Once we slowed down I let him know and his tires were only rated for 110 and since that day, I have decided to be a lot smarter with excessive speed in a truck....
Old Oct 5, 2024 | 10:58 AM
  #28
user 19972309843
I mean yeah you're not wrong there. However, unless I'm mistaken here, don't engineers usually set the limits lower than necessary for the general public due to stupidity of the general public? I mean I'm not trying to do 120+ or even 100+, but hell I can't go into the 90's safely for 20-30 seconds to be able to pass or put distance from someone else more efficiently?
Old Oct 5, 2024 | 12:33 PM
  #29
bentring's Avatar
bentring
Exactly! The powers that be (engineers&lawyers not the illuminati&one world order) decided unless you wanna void that warranty by a tune and delete on the truck you shouldn't be driving above X speed for any reason in these trucks. Besides, if you had went 120 the idiot who was tracking you would have just sped up too...
Not really sure how it's done on these but if you really want that bit extra anyway you might can oversize your tires and not adjust the cluster, or keep them but adjust the cluster to smaller tires? I just went from 31" to 35" on my '96 F350 and it's crazy to think that it now can go faster than a brand new one lmao.
Old Oct 5, 2024 | 02:05 PM
  #30
user 19972309843
Yeah you're probably right that the guy pacing me would've just caught up to me at which point he would've gotten the finger.
Cant change tire size due to the fact that I'll be using this truck for hotshot trucking. Pretty sure I need to keep it mostly stock
