No Electrical power
Old Nov 30, 2003 | 08:25 AM
jnet4jt's Avatar
jnet4jt
No Electrical power
The other day Ihad my distrubutor pulled and I didn't mark the alignment with the block. When I put it back in I went to start it and it ran real rough for about 2 seconds then it died now I can't even get any electrical power. Lights in the cab won't even turn on. It's almost like there is no battery hooked up. I checked all the fuses and the battery but i can't figure out what's wrong with the thing. One more thing, the reason i pulled the distrubutor is because there is a loud high pitch squelling noise comming from the lower aft part of the engine and i was checking to see if the oil pump drive rod was warped and it wasn't. Any thoughts would be a big help.
only makes the noise when I off the gas. and it does it nomatter if it is in neutral or any gear (5 spd).
Old Nov 30, 2003 | 04:07 PM
mcanik's Avatar
mcanik
Possibly when it kicked when you started it, a ground wire may have pulled away from the engine or perhaps a positive wire as well. Double check all the grounds first.
Old Nov 30, 2003 | 09:41 PM
jnet4jt's Avatar
jnet4jt
Thanks for the response, it was a bad connection on the terminal.
bmayden
Nov 1, 2012 08:27 AM
b4hntn
1978 - 1996 Big Bronco
Sep 30, 2007 09:04 PM
TexasGuy001
Jan 7, 2006 10:01 AM
fun98vette
1983 - 2012 Ranger & B-Series
23
Dec 29, 2003 11:42 AM
Bam531
Oct 18, 2003 09:45 PM
