Bushpilot
Or can I just cap these two off and be done with it.?? We don`t have the truck here at the moment but hope to in the next few months .. We get down to it ( Montana) about once a month and next time down ill get some pictures and numbers of the carb.. Any info on this is greatly appreciated
Norm
-If you have the round metal vacuum advance on the distributor with a vacuum line, then you do not have computer control.
-If you have no vacuum advance on the distributor, but instead have a rectangle plastic piece at the bottom of the distributor with a bunch of wires, you do have computer control and you should to the conversion to get rid of it.
The truck is actuality a U. S. one that we found at a salvage yard / garage in Montana .. Shane must have a couple of thousand vehicles there ,, some dating back to the late 30 s , 40, etc.. this 84 seems to have only been licensed till 88 or so.. Hence the low mileage 65 thousand.. When we bought it back in March this year it was missing the intake and exhaust manifold , the carb and a lot of the vacuum lines .. Since this is a garage as well we thought it best to leave the truck there and get it mechanically sound so it will be no problem for it to pass the import inspection.. This has been a very good decision.. They have parts there or are readily able to get them.. Keith (there head mechanic) said they have put over 20 miles on it since the new exhaust testing the different systems,, and last time down said the carb needed a lot more tweaking ... Working on the truck is just a fill in when they have time and thats ok with us as it keeps the cost down.... We have the factory manuals which are a big help and it does have the TFI distributor and I believe a processer ( hiding somewhere ) .. Next time down there I check with them and see if it can be switched to the Dura Spark II setup.... I`ll also take some pictures of the carb as well and figure bout how to post them.. Sorry for the long message,, And thank you again for replying !!
Norm
They wanted $400 dollars for it .. OOH Well ,, Hind sight is a wonderful thing.... All this electronic stuff as well as some of the electrical stuff is quite a mystery and I REALLY DO appreciate all the help.. Thank You Very Much .. Norm
A few wires will stay, they come from the driver's fender. That would be your new ignition wires, the oil pressure sensor wire, the temp sensor wire and a couple of others. You will probably need to add a wire from the "S" terminal on the back of the alternator, to your electric connection on the choke housing.
On the hoses you need to keep the one going to the brake booster, the one going to the HVAC which is on the pass side area, one going to the transmission if you have a automatic 3 speed, one going to the PCV valve in the air cleaner, one going to your new distributor.
the black rectangular thing to the right of the starter solenoid is the manifold absolute pressure sensor MAP
the MAP is the black thing
these 3 plugs are the EGR-TAB-TAD things. the unit they plug is not there also the vacuum hoses for them is gone also
this is the cad plated canister thing taped to the 2 vacuum hoses on the PCV valve.. The white stuff is snow !!
the right side of the carb. the black hose pointing down goes to the MAP.. the wire that goes up to the carb (held in place with a zip tie ) is also from the MAP and I don`t know if it is attached to the carb. or not
these are a couple more plugs dangling in space near the blocked off EGR
this is the left side of the engine.. The plugs, ignition harness , all the wiring , is what was on the truck when it was parked about 35 years ago.!!
here are a couple more connectors for something..
, electrical book that was right from FORD .. We live about 12 mile North of the border so it is very good to have a U S post office box.. That book should be there tomorrow or early next week.. It will be easier to trace this stuff out.. This was a standard truck, no chrome , no fancy paint trim , some of the wiring may have been there and used if it was the XL or XLT model.. Again I do thank all of you for the help on this..!! I hope you do get the pictures or maybe Trump sent them to Mars ! !
Norm
Before (not IF) those battery terminals leave you stranded, make sure you keep a pair of comfortable walking shoes behind the seat so you can still get home. Or I suppose you could just replace the cables.
Instructions on what to do with the old terminal here, post #16:
https://www.ford-trucks.com/forums/1...l#post18917218
the MAP is the black thing This will go away when the DSII is installed. Again I have not seen this talked about on other feedback systems
these 3 plugs are the EGR-TAB-TAD things. the unit they plug is not there also the vacuum hoses for them is gone also As you said they were for the 3 valves that were mounted to the valve cover. Because the computer will be removed and other things not hooked up now none of that will work. Wiring will be removed when the computer wiring is removed.
this is the cad plated canister thing taped to the 2 vacuum hoses on the PCV valve.. The white stuff is snow !! I believe this is the canister (under the battery for fuel vapor) purge again no computer no workie. On the older trucks this was done with a vacuum temperature switch setup. When you get the DSII up and running we can revisit this but not a big deal right now.
the right side of the carb. the black hose pointing down goes to the MAP.. the wire that goes up to the carb (held in place with a zip tie ) is also from the MAP and I don`t know if it is attached to the carb. or not There is a lot going on in this picture
The large hose with a plug in the end was from the air pump, that can stay the way it is for now, same with the EGR blocked off. The wire harness on the right side of the picture I believe is part of the feed back system and will be removed when the DSII is up and running. There should be only 1 wire now going to the carb choke housing down to the ALT S lug. It powers the choke only when the ALT is spinning / charging, we can help you with that too. The choke should have a metal tube from the EXH manifold to it to heat the choke also. Clean cool air comes from that hose at the top of the carb to the metal tube that stays.
these are a couple more plugs dangling in space near the blocked off EGR As said they will be removed with the DSII is up and running and the feed back computer & wiring is removed. I think that round plug went to the Tstat housing sensor to tell the computer when the motor was up to normal temp and go into open loop. Dont worry about them for now.
this is the left side of the engine.. The plugs, ignition harness , all the wiring , is what was on the truck when it was parked about 35 years ago.!! Again when the DSII is running the dist. and wiring to it will me removed. You can make out where the computer wiring comes thru the firewall in the upper right of the picture. See the oblong Gromit with the wires coming thru the other side is where the computer is. DO NOT remove wiring / computer till the DSII is running.
here are a couple more connectors for something. Them plugs are for options your truck dose not have like under hood light or trailer light relay. You can test each one to see when they get power and if down the road you need power for something you can use them.
Big thing is not to remove the computer & wiring till the truck is back up and running either with a DSII system or a aftermarket HEI drop in. Right now your timing is locked hurting power and MPG.
Dave ----
ps you done good on the pictures
The carbon fuel vapor canister is still there but not hooked up.. This is just a thought,, there was a carb. fuel bowl vent valve , and there was a simllar type valve from the carbon canister.. Is it feasible to have 2 Y connections , one at the fuel bowl and one at the canister with 1 of these thermal vent valves in each line but faced in opposite directions so the carb. could burn the fuel vapor when it wanted to and send fuel vapor down to the canister when it did`nt ?? I AM NOT TRYING TO RE INVENT THE WHEEL HERE HONEST Just a question.. What else can be done with the vapor from the canister ? We won`t get up to Lethbridge till Feb 8th for the Swap-N-Shop the car club we joined back in Dec is putting on So between that and stopping a couple of auto salvage yards we hope to come with the things we need to make the swap.. The dist would be 6 cyl . is the coil specific to that also does the module have to be for a 6 cyl ? In the mean time I`ll keep tracing the wires and get rid of the ones that go from one unused plug to another unused plug or socket, as the weather lets me..
Norm
Norm
Also there should be a sticker on the radiator support of the vacuum line routing you can look at like this off my 81 F100 with a 300 six
Dave ----
Norm
It's simpler to do nothing and let the gas tank breath through the canister into the atmosphere. I see someone has plugged the vapor connection on your carb. You will get a gas smell once in awhile under the hood. I talked to someone I work with that was working on this problem, and what he did was simply take the rubber gasket off the fuel filler cap. I have not tried this, but this is how the older cars worked. All newer fuel caps will let air in, but not let it out. Taking the gasket off may let air in and out, and eliminate the need for the line to the canister.
The module does not have to be a six cylinder. All blue plastic modules are the same. The ignition coil is DSII specific, and you need a horsehoe connector for it. The coil and the connector can be bought at the store. And don't forget the harness to the distributor. You can see now while the DSII is a good enough system and what Ford used on their vehicles, why people are just buying a new HEI distributor for your particular situation. It's the path of least resistance and can be cheaper depending on where you get your parts. You buy the HEI, stab it in place and hook one wire up, done. You can see the DSII system is more complex and takes more work to get installed.
I WOULD NOT willey-nilley cut unused connectors off. The best way to do this is to wait till you get the engine running. Once that happens, take the computer out under the dash. Unplug the large connector going to it. Fish the large connector through the hole in the firewall, you will have to punch out the rubber grommet. You may have a single wire or two going different places, you can cut them from the computer harness under the dash and carefully tape them. Push all the wires and connector through the firewall. Then gently tug on the wiring, Anything hooked to this large bundle of wires can leave, you do not need it. Keep tugging and unwinding things till the harness comes free with all that stuff hanging off of it. That is the safest way to remove it without cutting something that you might need later.
Because a lot of my smog stuff was removed before I got the truck, the purge system was one of them, I did what DaveF did and had vacuum pulling the fumes / vapor all the time.
Thing was it made a vacuum leak and the idle would not come down. I took the smallest carb jet I had and installed it in the vacuum hose to limit vacuum.
It helped a little but could have been a lot smaller, kind of like a pin hole size.
When I swapped out the factory carb for a Ebay knock off the carb did not have a bowl vent, yours has that yellow cap on it.
I removed the vacuum from the canisters, I have dual tanks, and left the hose open. Only time I get any vapor smell is if really hot out and I just filled the tanks.
I also park the truck in the house garage so we walk past it all the time otherwise I dont know if you would small it if parked outside?
Dave ----
