Power window rolls down by itself.
Thanks,
Dave
Thanks,
Dave
It did not work.
Tried to turn on of ignition multiple times and follow the push down, then release and hold again.
Up (bounce back occurred) then up again. (still bounce back) again release and hold (even though there was bounce back) and it does not fix the problem.
Time to take to dealer and have them sort it out?
It did not work.
OVERRIDING WINDOW BOUNCEBACK
WARNING: If you override
bounce-back, the window does not
reverse if it detects an obstacle. Take
care when closing the windows to avoid
personal injury or damage to your
vehicle.
1. Close the window until it reaches the
point of resistance and let it reverse.
2. Lift and hold the window control switch
within two seconds to override
bounce-back and close the window.
Bounce-back is now disabled and you
can close the window manually.
Note: The window goes past the point of
resistance and you can fully close it.
Note: If the window does not close, have
your vehicle checked as soon as possible.
Then try this to reset one press auto up and down
Resetting One-Touch Close
Carry out all steps within 30 seconds of
starting the sequence.
1. Close the window.
2. Press and hold the window control
switch until the window is fully open.
Keep the window control switch
pressed for a few seconds.
3. Lift and hold the window control switch
until the window is fully closed. Keep
the window control switch held for a
few seconds.
4. Press and hold the window control
5. Lift and hold the window control switch
few seconds.
Note: Repeat the procedure if the window
does not close when you use one-touch.
Good luck.
