Sponsored by: Auxito
power windows sluggish
Old Jul 17, 2004 | 03:05 PM
zekelander's Avatar
zekelander
Arrow power windows sluggish
My passenger side window has been moving alot slower than my driver side window. And you can hear a distinctive rubbing noise when it goes down. Before I tear in to it has anyone had this problem or done any power window servicing? Just want some advice.
Old Jul 17, 2004 | 04:24 PM
jreed27's Avatar
jreed27
The strip on the inside of the window is the cause. I'm not sure on the solution. It's very common.
Old Jul 17, 2004 | 05:37 PM
zekelander's Avatar
zekelander
Hey I appreciate it. I will take a look when I get of work to see if that fixes the problem. Thanks again
Old Jul 17, 2004 | 07:15 PM
Racerguy's Avatar
Racerguy
Also try lubing the window runs at the front and back of the window. The runs are where the window slides up and down in. Silicone spray or WD40 will work. Dont use anything thicker than that.
Old Aug 1, 2004 | 10:28 PM
dskarl's Avatar
dskarl
hey zeke,
have you tampered with the door before, cause theres a part called the money clip that holds the strip snug inside the door, take the door panel off and put some grease on the regulator, I posted a thread a couple up to the mirror thread and theres some info on how to take the panel off, Good luck! Dskarl
Old Aug 4, 2004 | 05:01 PM
zekelander's Avatar
zekelander
DSKARL, Sorry my reply took so long I havent got a chance to check my post lately but I will try that out. Is there some where, where I can get a picture of what that regulator looks like. Knowing me I'd end up greasing the window. Thanks again
Old Sep 19, 2004 | 02:33 PM
barrett's Avatar
barrett
my passenger side window just stopped working, it rolled down fine and i left it down then when i started the truck again later it wouldn't roll up
Old Sep 19, 2004 | 02:37 PM
pops_91710's Avatar
pops_91710
This has been my biggest beef about Ford Trucks and cars. They use an antiquated system. I am hoping my 2003 superduty won't get that way.
Old Sep 20, 2004 | 08:20 PM
03f150man's Avatar
03f150man
i had a dragging/slow window and the silicon spray suggested by racerguy fixed it. i gave it several light sprays over a 4 day period and the problem disappeared.
teamlx88
May 21, 2015 08:30 AM
ohioexwner
Jan 27, 2015 11:00 PM
rooboy
Jun 29, 2008 12:34 AM
JRCF
Feb 12, 2008 05:08 PM
wickware
Sep 8, 2004 05:49 PM
