Need Help Removing Starter
Old Sep 14, 2024 | 02:07 PM
FnS.73F100.build's Avatar
FnS.73F100.build
4wd Low
Exclamation Need Help Removing Starter
I have a 73' Ford F100 and the starter is giving me a hard time. As of this moment I am trying to replace the bad starter with a brand new one. However, I have come into a problem. One of the exhaust pipes are in the way of the bolt and the nut that is attached to said bolt. This bolt is also being bent out of shape making it hard to take off. If anyone knows how to remove an exhaust pipe or knows any tips that could help me it would be greatly appreciated.
Old Sep 14, 2024 | 05:04 PM
5851a's Avatar
5851a
Probably going to have to tell us what engine and what manifolds.
Old Sep 14, 2024 | 05:29 PM
FnS.73F100.build
4wd Low
It's a 360 engine and V8. 2 wheel drive and 3 speed automatic. It is a Ranger Custom if you need that too. Let me know what else you need and I will provide it.
Old Sep 15, 2024 | 10:57 AM
5851a's Avatar
5851a
I've used a very long extension and went at starter bolts from in front of the engine mount before. Rather than open up exhaust.
Old Sep 15, 2024 | 11:14 AM
tbear853's Avatar
tbear853
Long extension, and maybe a bit of tape in a socket to hold the bolt in it firmly at "put back together" time. If using any flex sockets, wrap a round of tape around the joint too.
You have no doubt, disconnected the battery.
CrewCabLongbox
Jan 7, 2014 12:59 PM
Crossbones5
May 18, 2012 07:54 PM
bettierage
Feb 12, 2011 04:54 PM
buckford
Jan 28, 2004 10:07 AM
standard23c
Sep 1, 2003 06:17 PM
