Broken bolt on starter
Old Feb 12, 2011 | 03:11 PM
bettierage's Avatar
bettierage
old starter in the 77 has been a piece for as long as its been in the family finaly got to point were i had to replace ofcourse now ic why th old cowbo who had before hadint done anything about it along time ago top bolt that holds it to the motor is broken can barley fit a wrench let alone a drill and extractor any got any idea how to get this starter off now?
Old Feb 12, 2011 | 03:13 PM
fmc400's Avatar
fmc400
MSEE
Is the problem just that the bolt head is snapped off? If that's the case, I'd try and remove the other bolt, and see if there is enough room to slide the starter away from the bellhousing, and then take it down. That should expose the shaft of the bolt so that you can get vice grips or a pipe wrench around it. I may not be totally understanding the problem though.
Old Feb 12, 2011 | 04:47 PM
bettierage's Avatar
bettierage
no u got the jist of it i can wiggle the starter around but not enough to see any thing havent realy tried to force its if i can just hulk it off will i get away with just retaping the threads or will i cause further damage?
Old Feb 12, 2011 | 04:54 PM
bettierage's Avatar
bettierage
its the top bolt between starter housing and the exhaust manifold there very lil space for ur hands let alone any thing other then a small wrench
andyofne
24
Oct 9, 2016 02:58 PM
AtlM5
Dec 13, 2015 07:57 PM
BigNug45
Aug 23, 2010 02:57 PM
hav24wheel
Jan 5, 2010 10:24 AM
rockher_man
Jul 10, 2007 01:13 PM
