1996 ignition control module
Old Sep 14, 2024 | 01:10 AM
NuclearDr's Avatar
NuclearDr
2nd Gear
hey guys, done my research. At least tried. Truck was running cold and wouldn’t get to temp and would shut off on me. Needed a new thermostat. Now it gets to temp and runs a lot better. However, I changed the ICM, I was suspecting this to potentially be an issue too according to some trusted old friends who drive ford trucks. I replaced the black ICM dy-1077. The truck drove much better after thermostat change, but every now and then it will crank like it’s misfiring or something. When I get to 35 mph it shakes really bad. Thought the ignition coil was causing this, but I changed it and it’s still shaking bad it. Driving down the road I got these 4 codes following changing my ICM- yes I replaced with another black DY1077 that I ordered from rock auto. Codes are now on all the time. Makes me think that maybe I need to change back to my old ICM, I’m not sure. What are your thoughts?
btw: truck specs - 1996 XLT 5.0 302 engine.
Old Sep 15, 2024 | 12:52 AM
Prototypemech's Avatar
Prototypemech
Check your fuel pressure.
https://www.ford-trucks.com/forums/1715944-how-to-check-fuel-pressure-on-1987-1997-gasoline-ford-trucks.html
Remove your distributer cap and blow compressed air at the PIP sensor at the bottom of the housing.
Old Sep 15, 2024 | 07:18 AM
Conanski's Avatar
Conanski
IDM is a function of the ignition module and notice that the old grey version doesn't have it. The likely problem is that aftermarket companies have abandoned the Ford black/grey color scheme so the correct module could be either color now.
Old Sep 15, 2024 | 12:32 PM
NuclearDr's Avatar
NuclearDr
2nd Gear
appreciate it. I heard in my truck, the dy-1077 should be the correct one but I’m not sure.
Old Sep 16, 2024 | 06:45 AM
rla2005's Avatar
rla2005
DY-1077 is the correct Motorcraft ICM for your 1996 model year truck. It's been posted here dozens of times.
Here is a good thread on the topic: Do you have the right ICM? gray vs black
As Paul stated the aftermarket ICMs tend to not be 100 compatible even though they are black. First clue is getting the missing IDM code even though the ICM is supposed a CCD version.
Old Sep 16, 2024 | 08:06 AM
manicmechanic007's Avatar
manicmechanic007
If you have misfires, the IDM circuit is doing its job alerting you
I would run through the pinpoint tests steps for that 1351 code after tuning it up and checking the fuel pressure
Don't just check the fuel pressure, drive it around with a pressure gauge on it
Anytime you have a module without the IDM circuit, you get the code (1994 and newer)
Buellrider76
15
Sep 18, 2023 09:38 PM
dmontano35
Jan 12, 2023 10:55 AM
Taaaylo
May 3, 2020 08:58 PM
daveengelson
15
Nov 18, 2016 08:36 AM
BradyCouchman
Mar 4, 2009 12:14 AM
