Once I properly installed the upfitter switch relay box, all was good. I just hadn’t taken the time to screw the relay box in place.
The only complaint I have is the pass through wires. They could for sure be longer so it’s not so tough to make connections. Because the wires were so far back and behind fuses under hood it was tough to work with.
