Sponsored by: Auxito
P0171 Code
Old Sep 1, 2024 | 10:22 PM
waldo16's Avatar
waldo16
P0171 Code
My trucks check engine light popped up and I scanned the system and it was showing P0171 code, I’ve replaced the PCV valve and two leaking vacuum hoses. I’m not sure what else it could be? And I check the Mass airflow sensor and it looks clean along with my air filter.
Old Sep 1, 2024 | 11:01 PM
steve(ill)'s Avatar
steve(ill)
if it is a V6, the intake manifold gaskets are questionable.. If it is the 5.4 V8, keep looking at the vacuum hoses.. two small 1/4 inch hoses about 8 inches long by the drivers side exhauses manifold get hot / crack / leak.... take each hose off ( all of them) one at a time and check for hard / crack / leaks and replace as needed.
Old Sep 2, 2024 | 12:14 AM
Jon Freeman's Avatar
Jon Freeman
Since it's only on one side it's likely a vacuum leak. If you're having trouble finding it, run a smoke test. Lots of videos on how to do it are available.
Old Sep 2, 2024 | 02:56 PM
BareBonesXL's Avatar
BareBonesXL
Says it's a 4.6.
https://www.ford-trucks.com/forums/1...l#post21302131
Old Sep 2, 2024 | 02:58 PM
BareBonesXL
@waldo16
Put your details here and people will know. Don't forget to scroll down and "Save...".
https://www.ford-trucks.com/forums/p...=editsignature
RusPro
4 Cylinder Engines
Feb 11, 2017 10:00 PM
Ben34
1997 - 2003 F150
Feb 11, 2012 05:21 AM
99EdeBauer
Jul 31, 2008 07:06 PM
blueharley
1997 - 2003 F150
21
Mar 9, 2005 06:54 AM
Cfdchf
Jan 15, 2001 04:46 PM
