tremor dummy hub
Old Sep 21, 2024 | 04:12 AM
  #31
Razorbackfan's Avatar
Razorbackfan
Navy Chief
So if I have them change this hub will the steering get easier?
Old Sep 21, 2024 | 09:17 AM
  #32
jimzpsd's Avatar
jimzpsd
No...........
Old Sep 21, 2024 | 09:35 AM
  #33
jcb804's Avatar
jcb804
Have to say over 13k miles on my personal truck and about 30k on the company trucks no issues from the dummy hub
  #34
Razorbackfan
Navy Chief
I just need to work on my arms in the gym. Been used to that F150 steering for years.
Old Sep 21, 2024 | 09:12 PM
  #35
Razorbackfan
Navy Chief
Anyone have a pic of the dummy hub? Does it look the same as the other side on the truck?
Old Sep 22, 2024 | 06:15 AM
  #36
senix's Avatar
senix
dummy hub does not have the selector on it vs the drivers side. Easy enough to know it is not a part time locking hub with the selector missing.
Old Sep 22, 2024 | 07:07 AM
  #37
capt caper's Avatar
capt caper
This is so odd. I took ownership of my xlt December 6th. I ordered it I think late Octomber. It came fast. Was built the week after the strike ended in Kentucky. The dummy hub posting came up last spring. I was shocked. Never knew I had it. Luckily I had only 2500 miles on it. Folks with Tremors reported they had the working hubs on both sides.
I was one of the first ones to change over to a working hub. I couldn't see how it would hurt the truck. Just didn't make sense. I took a chance. I had only to put the short vac tube on and the hub. Took about 20 minute. Tire stayed on.
After weeks or months others posted they didn't have both vac lines and had to order both. Also back orders were being reported for the hub's as well. Odd.
I'm reporting now I have 28k miles and everything is fine. Shifts in and out smooth still. Plowed all winter with it. Took my truck camper over 4300lbs across usa and back for a total of 11000 mile trip as well.
Seems I made a good choice. Good luck to those changing over.
Old Sep 22, 2024 | 07:35 AM
  #38
gatorblue92's Avatar
gatorblue92
Here is the dummy hub vs the auto hub. Took these when I swapped them both out for manual Warn hubs.
Old Sep 22, 2024 | 08:27 AM
  #39
ejb69's Avatar
ejb69
The the ability to be able the manually lock my hubs has saved my but a few times. Fords vacuum system fails. You have no 4wd. I earned this when I got stuck on a forest road . Locked the hub manually and drove right out. Not sure how long or want it have cost to get help back there.
Old Sep 22, 2024 | 08:38 AM
  #40
jimzpsd's Avatar
jimzpsd
There will come a time when your hubs will not lock as easy as they do when new, you'll need a pliers or some tool to assist in rotating them. I went through three pairs (warranty) until I finally replaced them with after market hubs....just like the old school set up and no more "auto lock", love it too.
Old Sep 22, 2024 | 09:57 AM
  #41
OBS460's Avatar
OBS460
It used to be regular maintenance to repack your wheel bearings and that was the perfect time to inspect, clean and grease your hubs. My OBS has the same all metal Mile Marker hubs since 2008 and they still turn as easy as they would if new. It is a 15 minute job to remove and service just the hub.
Old Sep 22, 2024 | 10:12 AM
  #42
ejb69's Avatar
ejb69
I use 4wd pretty often, if I notice the hubs not turning freely,I will lube them. I have been thinking of putting warn lock out hubs on my truck rather than Fords hubs . But , the factory hubs seem to work, so why spend the money for the warns is where I’m at.
Old Sep 22, 2024 | 12:25 PM
  #43
willynilly's Avatar
willynilly
perhaps if there were a how-to book in the glove box. it could be called dummy hub for dummys or somethin like that lol
Old Sep 22, 2024 | 01:29 PM
  #44
jimzpsd's Avatar
jimzpsd
Its when the large o-ring fails and leaks vacuum, hubs won't engage and this is why you can manually turn them. In my case all my hubs became corroded between the plastic actuator **** and the aluminum housing, (the aluminum surface will bind against the plastic) making it difficult to turn by hand. I use my hubs daily too, applied small amount of light machine oil in between the plastic/aluminum, water, salt, mud takes its toll. New Warns are in now and all is better.
Old Oct 9, 2024 | 05:49 PM
  #45
NYH1's Avatar
NYH1
Originally Posted by NYH1
The longer of the two required vacuum lines is on back order. That seems to be the story of my life this summer.
NYH1.
The hose came in yesterday. Gonna drop it off Sunday night and they're gonna install everything Monday.
NYH1.
