Jack and stands for 2wd front end
Old Aug 25, 2024 | 02:23 PM
Junktownbill99's Avatar
Junktownbill99
Originally Posted by AuroraGirl
Hmm.. I guess it can be used. Well, I wont be doing it on mine because they are quite rusty. Is it rusty enough to be weak? no idea but id rather not find out lol
Maybe its because its a 4x4, but mine are thicker than the frame. And I've dropped the frame onto a jack stand (was a crummy jack, no precision) these suckers could hold some weight. F150
Old Aug 26, 2024 | 11:14 AM
cougrrcj's Avatar
cougrrcj
For single wheel jacking, using a floor jack, I position the jack under the I-beam/radius arm bolt.
For front suspension work, the floor jack goes under the engine crossmember, and jack stands go on the forward frame horns. I've tried to put the jackstands to the rear of the radius arm bushings, but that seems to be a bit too close to the truck's CG
Old Aug 26, 2024 | 12:10 PM
Mastiff37's Avatar
Mastiff37
I don't trust hydraulic jacks if I'm going to be under the vehicle. For a break job, I'm okay leaving it that way, though I've had jacks leak down on me if the job draws out.
LandAndStone
Mar 28, 2023 09:01 PM
Deagle12
Feb 11, 2023 09:31 AM
82_F100_300Six
Aug 7, 2017 05:03 AM
P4IN COMM4NDO
16
Sep 26, 2016 12:02 PM
Nunez57
Feb 2, 2014 12:16 AM
