Clearing error codes after a fix
Old Aug 23, 2024 | 05:56 PM
Dave's here's Avatar
Dave's here
Replaced the solenoid pack on my 4R100 transmission and the truck runs like new again, but the error codes are still there on my Bluedriver scan tool.
Am a bit mystified, any ideas ?
Last edited by Y2KW57; Sep 19, 2024 at 01:25 AM. Reason: Marked thread for location of probable spammer. Cleared mark after banning confirmed spammer.
Old Aug 23, 2024 | 07:57 PM
John in OkieLand's Avatar
John in OkieLand
get the free ForScan app and use it to clear all DTCs
https://forscan.org/home.html
if you have a Windows laptop, get the USB wired adapter for the laptop.
that gives all of the functions of ForScan
Old Aug 24, 2024 | 07:15 AM
Packard42's Avatar
Packard42
shorting the battery cables together
I read you can disconnect the negative battery cable and then jumper or connect the negative to the positive cable for 5 to 10 minutes and clears everything. Have to re-learn shift points etc. Is this correct? I have two codes that forscan won't clear that I may have fixed after one of my 4x4 hubs came loose.
Old Aug 24, 2024 | 10:38 AM
John in OkieLand
that works also, it takes a while for the Capacitors in the PCM to bleed down...
well, at least it works on my Suburban, never tried on my 7.3L because I have a CTS-3 and it can read the PIDs and clear the codes.
DetailerDave
Jul 24, 2016 11:46 AM
MCKISHEN
Nov 24, 2007 07:35 AM
Pablo-UA
Aerostar
Nov 7, 2006 12:35 AM
RobertJohn
Dec 15, 2004 09:34 AM
