A.C. Expansion valve
Old Aug 21, 2024 | 04:23 PM
BadEX's Avatar
BadEX
Trailering
Hi,
I have a 2000 Ford Excursion Limited, 6.8 gas V10, 4x4, front and rear air.
just had a compressor kit and condenser installed. Seems to take a while to get cold.
i gave them an expansion valve to replace as well. Is there one in the front or just in the back passenger jack compartment? Because the one in the back looks original.
just wanted more info before I call my mechanics.
Thanks in advance for your help.
Nathan
Old Aug 21, 2024 | 04:25 PM
01__Excursion's Avatar
01__Excursion
The only TXV is for the rear, the front uses the metered orifice strainer.
Old Aug 22, 2024 | 08:03 AM
BadEX's Avatar
BadEX
Trailering
I just called and the mechanic didn’t change it out so I have to head back up there.
would the rear expansion valve affect the temp or performance of the whole system or just the rear?
Old Aug 22, 2024 | 09:13 AM
John in OkieLand's Avatar
John in OkieLand
it would keep the Rear unit from working like it should.
It will not effect how well the front unit works...
Old Aug 25, 2024 | 05:57 PM
01__Excursion
if the Freon charge is within spec, than only the rear is affected by a bad or failing TXV.
patrocle
Jun 3, 2024 08:55 PM
RobertH
Jul 26, 2022 05:40 AM
6_Myles
Mar 4, 2020 07:21 PM
bigperm2
Feb 28, 2016 06:53 AM
whits
Jun 28, 2007 02:59 PM
