Sponsored by: Real Truck
Key pad codes
Old Aug 22, 2024 | 04:42 PM
Tagski99's Avatar
Tagski99
3rd Gear
Key pad codes
Hi everyone, I’m looking for a list of codes for my 04 F450. I remember someone had generated a list of codes years ago when I had a similar problem with my 2000 Excursion. If that list still exists , I would appreciate a copy.
i tried looking for it behind the dash by the radio, because of health reasons I can’t get under the dash. I’ve seen videos on YouTube showing guys going in through a little compartment door on the dash, however, my truck doesn’t seem to have that little compartment. I also tried using the for scan software, but again that didn’t work. I wish I kept that print out from years ago, I was able to find the code with that.
thanks, George
Old Aug 23, 2024 | 10:30 AM
Pickupmanx2's Avatar
Pickupmanx2
Search it in the Excursion forums, when I got my 00 Ex a few months ago I printed it out and about halfway down found the code...
NVM, I found it,
Originally Posted by robert_l_ross
If I remember correctly, newer models (2002 and newer?) disable the keypad after something like 35 keystrokes. The fast way I know around it is what you did - reset via key...the slow way is to wait 1 minute.
Someone smarter than myself broke the string into groups to make it easy to find 35 digits. Remember, if you key in 20 digits, the last 5 open the door, so when you hit number 35, go back 4 or 5 numbers when you continue.
Oh, one last part...the first number that works MAY be the prior owners code. If you keep going you will probably hit a second code that works (how mine ended up playing out). I tried resetting the first code and it ended up being the personal code. I would keep going after the first code if your truck is a 2000 or 2001 and resetting the first code you find doesn't work -it means you are not using the "master" code for your truck. If you have a 2002 or newer, it's a 50/50 chance you hit the master code first and can erase the personal code without even knowing the code you are erasing. Clear as mud?
99991 11113 11115 11117 11119 11133 11135 11137
11139 11153 11155 11157 11159 11173 11175 11177
11179 11193 11195 11197 11199 11313 11315 11317
11319 11333 11335 11337 11339 11353 11355 11357
11359 11373 11375 11377 11379 11393 11395 11397
11399 11513 11515 11517 11519 11533 11535 11537
11539 11553 11555 11557 11559 11573 11575 11577
11579 11593 11595 11597 11599 11713 11715 11717
11719 11733 11735 11737 11739 11753 11755 11757
11759 11773 11775 11777 11779 11793 11795 11797
11799 11913 11915 11917 11919 11933 11935 11937
11939 11953 11955 11957 11959 11973 11975 11977
11979 11993 11995 11997 11999 13133 13135 13137
13139 13153 13155 13157 13159 13173 13175 13177
13179 13193 13195 13197 13199 13315 13317 13319
13333 13335 13337 13339 13353 13355 13357 13359
13373 13375 13377 13379 13393 13395 13397 13399
13515 13517 13519 13533 13535 13537 13539 13553
13555 13557 13559 13573 13575 13577 13579 13593
13595 13597 13599 13715 13717 13719 13733 13735
13737 13739 13753 13755 13757 13759 13773 13775
13777 13779 13793 13795 13797 13799 13915 13917
13919 13933 13935 13937 13939 13953 13955 13957
13959 13973 13975 13977 13979 13993 13995 13997
13999 15153 15155 15157 15159 15173 15175 15177
15179 15193 15195 15197 15199 15317 15319 15333
15335 15337 15339 15353 15355 15357 15359 15373
15375 15377 15379 15393 15395 15397 15399 15517
15519 15533 15535 15537 15539 15553 15555 15557
15559 15573 15575 15577 15579 15593 15595 15597
15599 15717 15719 15733 15735 15737 15739 15753
15755 15757 15759 15773 15775 15777 15779 15793
15795 15797 15799 15917 15919 15933 15935 15937
15939 15953 15955 15957 15959 15973 15975 15977
15979 15993 15995 15997 15999 17173 17175 17177
17179 17193 17195 17197 17199 17319 17333 17335
17337 17339 17353 17355 17357 17359 17373 17375
17377 17379 17393 17395 17397 17399 17519 17533
17535 17537 17539 17553 17555 17557 17559 17573
17575 17577 17579 17593 17595 17597 17599 17719
17733 17735 17737 17739 17753 17755 17757 17759
17773 17775 17777 17779 17793 17795 17797 17799
17919 17933 17935 17937 17939 17953 17955 17957
17959 17973 17975 17977 17979 17993 17995 17997
17999 19193 19195 19197 19199 19333 19335 19337
19339 19353 19355 19357 19359 19373 19375 19377
19379 19393 19395 19397 19399 19533 19535 19537
19539 19553 19555 19557 19559 19573 19575 19577
19579 19593 19595 19597 19599 19733 19735 19737
19739 19753 19755 19757 19759 19773 19775 19777
19779 19793 19795 19797 19799 19933 19935 19937
19939 19953 19955 19957 19959 19973 19975 19977
19979 19993 19995 19997 19999 33333 53333 73333
93335 53335 73335 93337 53337 73337 93339 53339
73339 93353 53353 73353 93355 53355 73355 93357
53357 73357 93359 53359 73359 93373 53373 73373
93375 53375 73375 93377 53377 73377 93379 53379
73379 93393 53393 73393 93395 53395 73395 93397
53397 73397 93399 53399 73399 93535 53535 73535
93537 53537 73537 93539 53539 73539 93553 73553
93555 53555 73555 93557 53557 73557 93559 53559
73559 93573 73573 93575 53575 73575 93577 53577
73577 93579 53579 73579 93593 73593 93595 53595
73595 93597 53597 73597 93599 53599 73599 93737
53737 73737 93739 53739 73739 93753 93755 53755
73755 93757 53757 73757 93759 53759 73759 93773
93775 53775 73775 93777 53777 73777 93779 53779
73779 93793 93795 53795 73795 93797 53797 73797
93799 53799 73799 93939 53939 73939 93955 53955
73955 93957 53957 73957 93959 53959 73959 93975
53975 73975 93977 53977 73977 93979 53979 73979
93995 53995 73995 93997 53997 73997 93999 53999
73999 95555 57555 59555 77555 79555 97555 99557
57557 59557 77557 79557 97557 99559 57559 59559
77559 79559 97559 99575 77575 79575 97575 99577
59577 77577 79577 97577 99579 59579 77579 79579
97579 99595 97595 99597 77597 79597 97597 99599
77599 79599 97599 99777 77977 79977 97977 99979
79979 9999
Old Aug 23, 2024 | 04:37 PM
Tagski99's Avatar
Tagski99
3rd Gear
thanks for this list. I'm sure I'll be able to get it eventually.
Old Aug 24, 2024 | 12:36 PM
Pickupmanx2
Really, grab a cup of coffee in the morning, or if evening grab your adult beverage of choice and start.. I used a pen to mark my progress so I didn't duplicate, maybe 10-15 mins and viola!
You'll be glad you did! Just wish my '02 F350 had the keypad
commandersander
Jun 7, 2023 07:55 AM
crazytwo
Jun 25, 2014 09:03 AM
hmolivas
2004 - 2008 F150
Oct 22, 2013 04:23 PM
78 PEB
Feb 10, 2011 01:35 AM
