OBD2 Ipad scanner
Old Jun 22, 2014 | 06:33 AM
crazytwo's Avatar
crazytwo
OBD2 Ipad scanner
Any recommendations? I'm looking for something that will give me more than trouble codes.
Old Jun 22, 2014 | 07:42 AM
Money-Pit's Avatar
Money-Pit
Here you go.
DashBoss | A Brain Scan for your Vehicle
Old Jun 22, 2014 | 08:33 AM
pgguru's Avatar
pgguru
Dash command
https://itunes.apple.com/ca/app/dash...321293183?mt=8
Old Jun 22, 2014 | 07:57 PM
crazytwo's Avatar
crazytwo
Thanks. Those look interesting. Anyone own either one?
Old Jun 22, 2014 | 11:00 PM
Stewart_H's Avatar
Stewart_H
You need to check out the posts and threads by Tugly in the 7.3L forum.
Stewart
Old Jun 22, 2014 | 11:29 PM
JohnInCanada's Avatar
JohnInCanada
I have DashCommand. It's good, but it's not awesome. I can't seem to get the Transmission temperature to display, or the Coolant Temp. Same result for EngineLink.
For a diesel, those are 2 very crucial numbers that I can't get.
Old Jun 23, 2014 | 12:25 AM
1 Excursion camper's Avatar
1 Excursion camper
I'm running Dash Command on my Iphone. Great app that displays alot of info. I have no problem with any of the temps (engine and trans no issues)! I'm using a WiFi dongle. I have about $40 in it not including the phone! I highly recommend it.
Old Jun 23, 2014 | 08:33 AM
JohnInCanada
Huh. I wonder if I have a bad sensor in my truck then.
Are you getting coolant temperature too?
Old Jun 23, 2014 | 08:53 AM
Patriotic Rottweiler's Avatar
I use the iTSX from SCT with my iPad 4. It works as a tuner and it can display up to 6 different measurements at a time (and there are about 20 different measurements that you can choose from, and change them whenever you want).
It also can read trouble codes and reset them.
Old Jun 23, 2014 | 11:37 AM
crazytwo's Avatar
crazytwo
I miss my Rottweiler.
Old Jun 23, 2014 | 01:07 PM
1 Excursion camper
Yep, engine and trans temp. the only thing it doesn`t show me is fuel remaining in tank. no big deal, but it would be nice to know exactly how many gallons remaining! otherwise it all works great!
Old Jun 23, 2014 | 11:13 PM
JohnInCanada
sonofabitch. I think I have bigger problems than I thought.
Now the question is: am I having problems because of my cheap Chinese WiFi OBDii sensor? Or am I having sensor problems in my truck?
I'm a little scared for the answer...
Old Jun 24, 2014 | 09:37 AM
volthause's Avatar
volthause
Don't sweat it. He's a gasser. If I recall correctly, the diesels don't report coolant temp through OBDII, it's straight to gauge.
Trans temp is reportable, but I don't know how to tell you to access it. I have a ScanGauge and had to enter codes to get the trans temp.
Ford/Lincoln/Mercury Specific : Linear Logic : Home of the ScanGauge
scroll down to the diesel section to see what I mean.
Old Jun 24, 2014 | 12:47 PM
Stewart_H's Avatar
Stewart_H
Damn Scott, long time no post!
Stewart
Old Jun 24, 2014 | 01:05 PM
volthause's Avatar
volthause
Stewart
I've been in lurk mode.
