New engine air filter change question
Old Aug 22, 2024 | 04:35 PM
srkr's Avatar
srkr
Originally Posted by CBEllis
Nah - it's in the settings, just like resetting the oil life monitor. It tracks a combo of the running time and mileage - it's not a real air quality monitor. You can just reset it in the vehicle settings.
After pulling mine IT needed it badly, the dust and dirt were horrible, I had to actually vacuum out the box with a shop vac after the old filter was removed. I will never second guess that warning.
Old Aug 22, 2024 | 05:42 PM
jimzpsd's Avatar
jimzpsd
Originally Posted by Ltngdrvr
Heck, at least yours works.
Filter on mine was almost totally blocked, and the monitor still said all was okay.
Either your air box has a leak and is sucking in unfiltered air, the gauge is defective or the filter "looks dirty" but still has enough clean pleats to breath properly.
Old Aug 22, 2024 | 06:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
No, was so blocked with dirt that the pcm thought the MAP sensor was not in range, turned out to be a clogged up air filter, or more accurately, the pre-filter.
Took the pre-filter out, cleaned it and reinstalled it and all was well.
fordman19762003
Jun 15, 2021 12:16 PM
Cwsocks
6.2L V8
15
Dec 27, 2016 09:28 PM
Pyrexic
Nov 9, 2006 08:30 PM
SC_Dave
29
Oct 17, 2005 05:44 PM
rnissen
Nov 12, 2001 02:27 PM
