6.2 air filter question
Old Jun 11, 2021 | 11:57 AM
fordman19762003's Avatar
fordman19762003
On the 2017+ 6.2 airfilters the bottom of the filter base has a couple plastic tabs that come out on the one side. Do these need to be facing a certain way or does it only matter that the two round guides are facing down? The filter fits the same way when they are facing opposite sides so I can't figure out why the tabs are there.
/also, how long are you guys going on filter changes? I usually go 12k on the engine filter and around 15k on cabin filter but the engine filter was fairly clean at 12k. Manual says 30k under normal conditions which I think is pretty excessive, they are spot on for changing the cabil filter at 15k because they are very dirty by then.
Old Jun 11, 2021 | 12:37 PM
crewzer's Avatar
crewzer
I can’t explain the tabs. I installed a new engine air filter at 20K miles using the same orientation as the original.
30K miles for the engine filter is subjectively too long for me as well. I changed both the engine- and cabin air filters at 20K miles.
HTH,
Jim / crewzer
Old Jun 11, 2021 | 12:55 PM
fordman19762003
HTH,
Jim / crewzer
Which way were the tabs facing? I never even thought to look when I removed mine but from the dirt trail on the filter it appeared the tabs were pointing towards the passenger side fender.
Old Jun 12, 2021 | 07:27 AM
crewzer's Avatar
crewzer
Tabs on mine are “facing the engine”, so to speak.
HTH,
Jim / crewzer
Old Jun 12, 2021 | 09:40 PM
fordman19762003
HTH,
Jim / crewzer
Thanks, I have mine the opposite way. Wonder if it really makes a difference since it appears to fit the same both ways.
Old Jun 13, 2021 | 07:11 AM
tibadoe's Avatar
tibadoe
I have to say I never paid attention to which way the tabs were facing when I removed the original air filter. Will have to look and see which way I put it back in.
Old Jun 15, 2021 | 12:16 PM
whagen's Avatar
whagen
the air filter house may have been designed to fit that air filter. Maybe is some other application that tab has a function. Every time I change my filter I forget to pay attention to which way it came out and go through installing it both ways and seeing if there is a difference and end up just leave it in which ever way I last tired.
macguy
6.7L Power Stroke Diesel
Dec 20, 2012 07:23 AM
utjer
Jun 2, 2010 05:23 PM
