My change engine filter soon came on, went to auto zone and replaced the new air filter and center instrument cluster still says to change filter soon. Could not find it in the cluster screen. Will it auto reset when I drive it tomorrow?
2023 6.7 F250.
Thanks.
RESETTING THE AIR FILTER REMINDER 1. Press the menu button on the steering wheel to enter the instrument cluster display main menu. 2. Select Vehicle Maintenance. 3. Select Engine Air Filter. 4. Press and hold the OK button until the system reset confirmation appears. Note: The system displays 100% after being successfully reset.
Reason: update
Nah - it's in the settings, just like resetting the oil life monitor. It tracks a combo of the running time and mileage - it's not a real air quality monitor. You can just reset it in the vehicle settings.
I will have to look again. I don't think my 22 has that if I remember correctly. It just says Engine Filter Status and when you click it it just says OK, there is no percentage.
