rotor position
Old Aug 21, 2024 | 05:03 PM
needle13's Avatar
needle13
3rd Gear
rotor position
I have a 59 F100 Panel with a 292. I am reinstalling the distributor and need to know the position of the rotor at tdc.
Old Aug 21, 2024 | 08:33 PM
spurredon's Avatar
spurredon
Welcome to FTE! Look thru this thread. It has a lot of info you while be interested in. 292 distributor install problem - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Aug 22, 2024 | 12:51 PM
needle13's Avatar
needle13
3rd Gear
So, I followed the advice lining up the distributor and still no fire. It doesn't sound like it even wants to fire. Should I do a compression check on all the cylinders to make sure I have compression?
Old Aug 22, 2024 | 02:11 PM
MARC's Avatar
MARC
Rotor
Make sure adequate power to coil.
78F-250Lariat
Nov 8, 2014 06:22 AM
Blue50F-1
Jun 24, 2013 04:44 AM
duhrbroc
May 31, 2009 11:17 AM
Mreddd
Electrical Systems/Wiring
Oct 14, 2005 11:45 PM
250K AS
Aerostar
Jul 14, 2003 10:40 AM
