Door switch Replacement
Old Aug 20, 2024 | 06:56 PM
79F150400M's Avatar
79F150400M
I don't want to break the new switch so what's the best/easiest way to connect the wires.
Old Aug 20, 2024 | 08:32 PM
tbear853's Avatar
tbear853
As I recall, the switch just screws back outwards to the left until free from the jamb, then pull it out a short ways and there's the wires. I believe the wires plug into the back of the button switch.
Old Aug 20, 2024 | 10:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Are they not just push on connectors? I know that once you get the elec connection figured out and then put it back in the hole and lock it in place with the nut. And the 1st time you close the door the switch will sort of like self set to the depth needed.
Old Aug 20, 2024 | 10:36 PM
79F150400M's Avatar
79F150400M
That's the part I'm struggling with....how to connect the wires to the new switch. Does the white part detach from the switch?? I'm afraid to pull too hard for fear of breaking it. The white part that is attached to the wires is what's left of the original switch...I'm sure those will just get cut.
Old Aug 21, 2024 | 06:36 AM
77&79F250's Avatar
77&79F250
Maybe some help in here?
https://www.ford-trucks.com/forums/1...tch-wtf-2.html
https://www.ford-trucks.com/forums/1...placement.html
Old Aug 21, 2024 | 08:19 AM
HertzHound's Avatar
HertzHound
Seeing your post from an iPhone, it looks like you still have a piece of the old switch broken off in the plug? Remove whatever metal is stuck in the plug, and it should go onto the new switch.
Old Aug 21, 2024 | 10:20 AM
79F150400M's Avatar
79F150400M
Ok..I'll try that. Hopefully it will be plug n play. Thanks!
Old Aug 21, 2024 | 10:21 AM
79F150400M's Avatar
79F150400M
Appreciate everyone's help. You guys are great!
Old Aug 22, 2024 | 07:42 PM
79F150400M's Avatar
79F150400M
I got it figured out. I pulled the old one apart and realized it had a plug so all I had to do was plug it into the new switch. Silly me...I was over thinking it.
I cut the wires then realized it will plug into the new switch...so cutting the wires wasn't necessary. Had to solder them back together.
annaleigh
May 20, 2023 04:12 AM
madpogue
25
Jan 4, 2023 06:59 AM
Dean06919
Nov 18, 2016 11:31 PM
borland
34
Jan 7, 2015 10:15 PM
Aftrmidnite
Dec 25, 2013 05:44 AM
