Door jamb switch WTF?
Old Apr 4, 2017 | 02:11 PM
Superblue400's Avatar
Superblue400
Thanks to whomever participated on this topic awhile ago - was just about to go through returning my Rock sourced switches back thinking they were not going to fit.
FYI - Found this thread by using a Google search - the FTE search did not return this - maybe my string was too long?)
Old Apr 4, 2017 | 04:08 PM
madpogue's Avatar
madpogue
Or too short... A lot of these forum searches don't work well on very short words.
Old Aug 12, 2020 | 12:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Subscribed to save this good info for later.
Old Aug 12, 2020 | 04:24 AM
Kyla's Avatar
Kyla
it looks so different! maybe you can call the 4s shop?
Old Aug 12, 2020 | 04:53 AM
Geppi's Avatar
Geppi
yes ... the switches set themselves when closing the door for the first time. I was also surprised at the beginning.
actually a very simple and simple system ... like so many things in old American cars. European automobile manufacturers should take a look at that! everything is complicated with our cars.
Grüße aus Deutschland :-)
Old Aug 14, 2020 | 11:46 AM
dustyroad's Avatar
dustyroad
the forum search is less than desirable. pages of nothing relevant because someone mentioned a word you are searching for but has nothing to do with the problem at hand.
Old Jan 25, 2021 | 12:00 PM
lisagoud's Avatar
lisagoud
I crossed the number EOTZ-13713-A and it comes out to a motorcraft sw-1635. probably just a typo up above.
Old Mar 23, 2022 | 05:06 PM
Dirty D's Avatar
Dirty D
Door jamb dome switch
Originally Posted by madpogue
Anybody had to change out a door jamb switch? One of 'em on the '85 has been sticking, so I threw one into my last RockAuto order. Came today, went to install it, and WTF it's different. Sticks out from the door jamb a lot more than the old one. Threads in the same way, but I'm sure the way it sticks out, as soon as I shut the door I'm sure I'd destroy it.
So I figure it's a bad web listing. But I looked at LMC, Graveyard, even AutoZone, and their pics all show the same too-long switch. I can't imagine this new switch working in the truck, eh?
The threaded collar slides on the shaft of the housing. Install it and slowly and carefully close the door. Done. Fixed.
Old Mar 23, 2022 | 06:42 PM
madpogue's Avatar
madpogue
Necro-post. Yup, with the encouraging words of @85lebaront2 , I did just that, and it still works.
Holy Ned, I'd forgotten that I've had this truck for 10 years now....
Old Jan 4, 2023 | 12:13 AM
429f15077's Avatar
429f15077
6th Gear
Wiring
I know this is an old thread but could you tell me how to wire the three wires up? My old one only has 2 wires
Old Jan 4, 2023 | 06:59 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Wiring door jamb (courtesy light) switches
The switches simply connect the 2 or 3 wires to turn on the courtesy lights and the key in/headlights on warning buzzer or chime. Light Green/Yellow is power (hot at all times). Black/Light Blue is courtesy lights feed and Red/Pink is warning buzzer feed. Third pin is probably for security alarm on later trucks. Physical dimensions of these switches (thread size and length) didn't really change, just the wiring.
Hope this helps.
borland
34
Jan 7, 2015 10:15 PM
johnny yahoo
Aug 9, 2014 08:22 AM
RichardPerry
Jan 23, 2012 06:18 PM
mytbtruck
Jan 16, 2012 07:20 PM
