Sluggish starter
Old Aug 16, 2024 | 12:13 PM
Crop Duster's Avatar
Crop Duster
Originally Posted by Lee'sFord
The 9 tooth would grind when starting. It wasn't right. The 10 tooth is smooth, just doesn't want to turn over. After all the replies, i think testing for power is step 1, testing the starter is step 2. It's just baffling to ne hiw changing 2 parts can throw a wrench on the monkey works
If you have a C6 it should have a 164-tooth flex plate. It uses a 9-tooth pinion. Your block plate has to be for a small block with a 164-tooth flex plate if you used a block plate for a 184-tooth flywheel it would set the starter too far away from the ring gear. And the starter must be for an automatic transmission. If the 9-tooth starter you had was for a manual transmission it would grind because the manual transmissions flywheel is only 3/8 inch from the block plate an auto trans flex plate is 3/4 inch from the block plate. I think you have a bunch of mismatched parts.
Old Aug 16, 2024 | 01:55 PM
Lee'sFord's Avatar
Lee'sFord
I bought a scrap truck. I only bought it for the engine. I'm not sure what transmission was behind this motor. I didn't get it when I bought the truck. Sounds like I may need a new flex plate with the 9 tooth starter. I'll let ya all know what i find out.
Old Aug 16, 2024 | 10:06 PM
SwampRattFord's Avatar
SwampRattFord
If it were me I’d drop the starter and engage it out of the bell housing and
assure it runs correctly. It sounds like it might be binding when engaging the ring gear.
Aenima19
Jan 30, 2024 09:03 AM
Adam Chrisman
Mar 19, 2023 01:41 PM
Machspeed
Feb 18, 2022 12:35 PM
rrobinson54
Nov 19, 2020 04:49 PM
StrongRepublican
22
Feb 19, 2007 02:20 PM
