I recently purchased this truck need someone to help decode the vin please Vin tag on Drivers door F60DCF74037 Not in bad shape farm grain truck all her life.
F74037 = 1969 numerical series, Probably August 1969 production--fairly late in the run. '69 numbers went through G30,000 per the MPC but only F63,999 per the shop manual.
174 = 174 inch wheelbase
T = Red
F600 = F600 gas, 4x2, 19,500 lbs GVWR
4B81
4B = Black Leather Grain Vinyl
81 = Standard Cab, cab and chassis vehicle.
A = New Process model 435 four speed transmission
F2 = Eaton model 15201 two speed rear axle, 15,000 lbs capacity, 5.83 / 8.12 ratios
No front axle code. Only optional axles were shown '64 to '69. Thus, a Ford axle with at least 4,500 lbs capacity without power steering.
19500 = 19,500 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
46 = Indianapolis District Sales Office
No special order.
Thank you for the quick reply. Appreciate the information. Id say based in looking at the rims they are rhe widowmakers i here were pretty standard. Prob should look to replaxe rhem.
