Replacing Engine - Suggestions?
Old Aug 13, 2024 | 06:49 PM
skyw106's Avatar
skyw106
2nd Gear
Due to some low compression I’m replacing the engine in my 01 with a used 250k mile engine. While I have the cab lifted and donor engine on a stand: going to do all seals and gaskets plus manifold & up pipes.
what else should I replace?
Old Aug 13, 2024 | 07:09 PM
z31freakify's Avatar
z31freakify
Weldable oil dip stick adapter.
Old Aug 13, 2024 | 08:00 PM
97-psd's Avatar
97-psd
Plan for upgraded turbo or injectors?
lpop would be easy while on the stand. Have you heard this engine run?
Old Aug 14, 2024 | 08:58 AM
Kwikkordead's Avatar
Kwikkordead
I second this. With a quarter million miles on this engine I would also give a close eye to the piston cooling jets while the oil pan is off.
Old Aug 14, 2024 | 11:25 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Perhaps an O-ring reseal kit? Are the plenums still air tight?
Old Aug 16, 2024 | 01:47 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Agreed with all above.
Pay attention to the oil pan. If it's rusty replace it. Do the weld in dipstick adapter, maybe bed coat it if you can expect rust in your area, and the proper RTV curing procedure on install.
Rebuild the oil cooler. Replace the engine block heater if you are in a cold place. Both cheap insurance.
Get bellowed up pipes and dry fit them on the bench to the turbo before install. I got cheapo Dormans and the alignment pin was fubar, required some grinding.
Old Aug 24, 2024 | 08:06 PM
skyw106's Avatar
skyw106
2nd Gear
yes, engine is from a family members truck that is still running. Title issues is reason I’m parting it
Old Aug 25, 2024 | 10:09 AM
FordTruckNoob's Avatar
FordTruckNoob
You didn't say if this is a ZF6 or 4R100 truck. This is more relevant for a ZF6 truck but do the engine valley rear drainpipe mod. That will keep any leaking fluids from the valley from contaminating the clutch and the inside of the bell housing relatively clean.
Old Aug 25, 2024 | 07:06 PM
Dan V's Avatar
Dan V
And, if it's is a ZF6, get a hold of @akcooper9 for a replacement pilot bearing kit.
Old Aug 26, 2024 | 12:48 AM
udsuth78's Avatar
udsuth78
I've seen a good handful of front cover leaks roll through this forum over the last year or so. At least 3 were directly under the HPOP making them somewhat of a bear to pinpoint. I'd probably consider a fresh gasket and RTV to avoid potentially having to pull the motor back out in the near future. How about the rest of ya? Worth the price of the gasket set and hour or two it'll take to get out in front of that leak?
Old Aug 26, 2024 | 08:44 PM
WNYPSDguy's Avatar
WNYPSDguy
Flex plate? Helicoil starter bolt holes (deep helicoils for more threads). Oil galley plugs, esp rears. Depending on new engine condition, valve springs and glow plugs. easy when on a stand…. 50 cent mod. Too. Wrapped uppipes and turbo down spout. turbo rebuild. List is endless until you run outta bazooka bucks,
Old Aug 27, 2024 | 06:04 AM
kenn_chan's Avatar
kenn_chan
Talking
RUN OUT OF BAZOOKA BUCKS.... heresy I say, heresy!
soondg
Pennsylvania Chapter
Sep 7, 2017 07:19 PM
laptopgeek
May 7, 2002 08:12 AM
