I think I’ve seen aftermarket replacements for the stock subwoofer location. Do that, 4 new aftermarket door speakers with a 5-channel amp, and that would be a good upgrade.
Remove the woofer and add poly-fil. Then put sound deadening mat on the exterior of the box. Cheap and easy and sounds a little better.
They do have a drop in replacement for the woofer if i'm not mistaken.
Interesting idea, I'll check into it. Any idea what I should search to find that drop in replacement?
