Another Brake Thump Question
Old Aug 14, 2024 | 01:50 PM
bobbrinksster's Avatar
bobbrinksster
4wd Low
Thank you ... yes it repeats but I generally ease off the pedal when it starts so not entirely sure how long it would last ... will try and post something this evening or tomorrow morning.
Old Aug 14, 2024 | 02:23 PM
HRTKD's Avatar
HRTKD
Starting to sound like the ABS.
Old Aug 14, 2024 | 03:17 PM
bobbrinksster
4wd Low
Thank you again for the input ... thinking through this ...
ABS ... (basics)
1. Brake pedal is pushed
2. Wheel sensors detect skidding or 'locking'
3. ABS pumps (releasing the brakes) the brakes by pulsing fluid flow to the brakes.
Pumping the brakes might be triggering the ABS module into thinking that a skidding event is taking place or the sensor is misreading the pumping of the brakes as a 'locked' condition.
Researching to see if there is a way to monitor the sensor output as that would help in determining where, if there is an ABS issue, the issue might be.
Old Aug 14, 2024 | 03:41 PM
HRTKD's Avatar
HRTKD
ABS ... (basics)
I doubt you're the only Ford truck owner to pump the brakes. The ABS should be triggered by a difference between the wheel speed sensors. If you don't see the Slip light on the dash then it makes it less likely that the ABS is reacting to a speed sensor unless a speed sensor is reporting incorrect numbers.
Have you checked for stored trouble codes?
Old Aug 14, 2024 | 04:03 PM
bobbrinksster
4wd Low
Agree ... not the only nor the first ... Correct, the difference in the wheel speed between the wheels. No Slip light and no stored codes.
Thank you for responding. Will have more input later this evening.
GetMore
Jun 3, 2024 06:40 PM
dtupper1
Jun 30, 2020 03:09 PM
pitbulls20
May 18, 2008 11:03 PM
Baja Daze
May 24, 2007 12:16 PM
wcurtis
Jan 15, 2007 09:24 AM
