Rear tank lines
Old Aug 4, 2024 | 09:24 PM
7.3 turbo idi's Avatar
7.3 turbo idi
3rd Gear
Rear tank lines
Hi,
I got a 1994 F250 and the previous owner cut the rubber lines that come out of the rear tank sending unit. Is this an easy fix? Where do I get the lines?
Thanks
Old Aug 5, 2024 | 06:16 AM
Olds64's Avatar
Olds64
Do you see the cut rubber hoses in the frame of the truck? If so, you might be able to just replace 2 lengths of rubber hose.
Old Aug 6, 2024 | 06:21 PM
gespeter's Avatar
gespeter
Use good quality hose, as the regular SAE 30R9 is pretty good. Don't use anything lower. I actually prefer "barrier" line as it's the least permeable.
Ford used nylon line on most trucks. You can go that route, using small sections of hose to join nylon to other fittings. Best to use the "Fuel injection" clamps as opposed to standard worm clamps. The goal is to never have to crawl under there again, and keep the diesel fuel off your arms...
SexyPterodactyl
Sep 24, 2022 04:35 PM
ericboj
Jun 2, 2014 08:35 AM
Roy C
Apr 11, 2010 09:42 PM
TheBlueMule
Feb 5, 2008 04:48 PM
kdwelch
Jun 1, 2006 04:29 PM
