Rubber fuel hose replacement
I'm sure this has been covered before, though can't seem to find the specifics. I have a 92' F250 7.3 idi and plan on replacing my fuel and return lines to my primary tank (forward mid-ship tank) as my fuel lines are too rusty to salvage. Completely disconnecting the aft tank. I've dropped the primary tank and am installing a new sending unit and a new Facet lift pump as well.
I know I'm going to catch hell for this, but I wanted to replace the steel fuel lines with rubber hoses instead. I live on the Hawaiian coast and the rust is impossible to keep up with. I understand the issues, but If I take care in installing the rubber hoses with protective sleeves (for heat and rubbing) while using 'P' clamps then I don't foresee any issues, unless there is something I'm completely missing?
I'm also trying to lock in the exact fuel lines ID sizes used. From what I can find, the fuel hose ID's seem to vary from 1/4" to 3/8" for this engine/year. I understand that the fuel hose is a different size than the return.
If I do wind up using rubber hoses, does anyone know what sizes I would need? My sending unit hasn't arrived yet, so I can't go off of that and my old one is too rusted to get an exact measurement off of.
1/4" might be for the return lines from the Injectors on the 7.3 IDI.
So the 92 yr model used steel fuel lines instead of the plastic one`s?
My 86 uses plastic tubing from both tanks to the FSV, then plastic forward a ways
and connects to a steel line. Then a rubber hose up to the Water separator/filter,
then loops back down to a steel line under the engine over to the Lift Pump.
4 years or so back I swapped the rear 19 for a 38 gallon tank. I replaced both senders and Shower Heads.
I covered the top of the Senders with Anti-Seiz thinking it might keep the tops from rusting.
Had problems with the FSV this summer...long story.
I now run rubber hose from the rear tank to the engine and back.
Iam using the front tank for a transfer tank, to pump to the rear, and going to use the Facet electric pump.
Just don`t have the electric connected to the pump yet.
Charlie
Thanks for the info though!!! Very helpful again...
Having 2 tanks is nice for sure, but I always wondered why they didn't just run a rubber hose between the bottoms of the 2 tanks and call it a day. Heavy trucks use that setup and it works great, no valves and switches and BS to fail. If you were having problems with that stuff (very common, many do) I can't blame you for ripping it all out.
https://www.eaton.com/ecm/groups/pub...t/pll_1173.pdf
Get lines cut at a heavy-truck repair shop.
Roy
Nothing wrong with plastic line, big rigs use it for the Air Lines also for the Brakes system.
probably comes in a role in a box, it will have to be straightened out, and probably some
heat applied to make the bends you need.
Dorman makes the push on fittings like go on the Senders at the Tank and FSV.
And also push on splices.
Some how my supply line from the rear tank came out of the Frame Clip, and was hanging
down to where I guess it got pinched between the Axle and Bump Stop. used a Dorman
Splice and a section of fuel line I got from PNP. Worked great.
I guess it was back in June I was messing with that %#@&% FSV, it was pulling from rear
tank and returning to the front tank. Eliminated the FSV and tried to splice the plastic lines
with the Dorman Connectors. Could not get them to quit dripping. So pushed 3/8" rubber
hose onto the plastic line. But it does not go into the hose very far, I clamped it on and so
far, so good. It is not under pressure, just suction. But could be a cause of air into the system
if the rubber shrinks with age.
The return line is no big deal, not under pressure.
Some Rubber fuel hose can get pretty pricey.
There are YT Video`s showing how to heat the plastic line to push the barb fittings on.
Also there are tools to shove the 2 parts together, but pricey.
And other DIY ways.
Just thought I would throw out my thoughts and trials and tribulations,....
Charlie
