Fuel tank selector
Old Aug 3, 2024 | 12:40 PM
Modmoron 05's Avatar
Modmoron 05
2nd Gear
Fuel tank selector
Long story short have a 1987 F150 dual tanks sitting since 2000 new tanks senders filter and new high and low press pumps. Flush lines went to clean selector valve it has what used to be gas on both sides of the diaphram don't think is good and the metal backing plate is rusty as crap. Thanks
Old Aug 3, 2024 | 03:37 PM
jas88's Avatar
jas88
Those are pretty hard to find I understand. Too late now but a better way to go, IMO, is to convert to the ITR system they started using in 1990.
Old Aug 3, 2024 | 05:08 PM
OldTrucksAreBetter's Avatar
OldTrucksAreBetter
If you have the Dual Function Reservoir (4 line connections on one side and 2 connections on the opposite side) and it’s because unserviceable then search F1UZ-9B263-B and you should be able to get another one. If you have the Single Function Reservoir, they are harder to locate now but you may find at junkyards.
Building_Fords
Nov 12, 2018 12:51 PM
ARoby0618
Apr 12, 2016 05:04 PM
iwals
Feb 19, 2016 08:27 PM
JakobFrick
Dec 9, 2012 04:27 PM
Eric1986
Oct 26, 2007 09:24 AM
