89 f150 5.0.
Has anyone just deleted the reservior completely? I have no use for 2 tanks and have a valve messing up and allowing fuel into the wrong tank, so just curious if anyone has deleted it and if so what all needs to be done.
To swap to the later fuel system you would need the fuel lines and a tank with FDM from a '90+ truck, or you could simply swap in a single function resovoir from an older single tank truck. The device currently on your dual tank truck is called a dual function resovoir.
The reservoir is just that...a reservoir. Removing it may result in stalling when the vehicle is going up hill or at other angles. Everyone highly suggests getting a Single Fuel Reservoir as a replacement.
