Sponsored by: Auxito
Rear diff specs
Old Jul 30, 2024 | 03:01 PM
waldo16's Avatar
waldo16
Rear diff specs
I was wondering if the rear diff cover has a specific torque spec? I have an 8.8 cover, I think lol. I’m using RTV and is it alright to use limited slip in a non limited slip diff?
Old Jul 30, 2024 | 03:09 PM
RLXXI's Avatar
RLXXI
What are you working on? year/model/trim,/etc... it matters.
Old Jul 30, 2024 | 03:15 PM
waldo16's Avatar
waldo16
im working on a 97 f150 super cab with the 4.6 V8 with 2WD
Old Jul 30, 2024 | 04:45 PM
RLXXI's Avatar
RLXXI
Look at the door jamb sticker (if it's still legible) and post what the code is for the axle, example below.
Old Jul 30, 2024 | 05:19 PM
waldo16's Avatar
waldo16
All it says is “Axle: 19” is that the code for it? Sorry I’m not sure what to look for
Old Jul 30, 2024 | 06:03 PM
RLXXI's Avatar
RLXXI
19= 3.55 gear, coupled with a 2wd 4.6 it's extremely likely it's an 8.8 ring gear. They have 3 different axles listed, 8.8, 9.75 and 10.25 for this year span. It is a traction lock axle meaning it requires limited slip gear oil. (Has clutches inside)
Cover bolts are 28-38 lbft.
Old Jul 30, 2024 | 07:44 PM
BareBonesXL's Avatar
BareBonesXL
There should be two metal tags on the diff cover bolts. One has the type of oil needed and the other has the type of internals. If there's an L in the ratio it's limited slip. 3 55 or 3 L 55.
If you have an open diff it won't hurt to use oil with the additive already in it.
ketterg
Aug 4, 2021 09:37 AM
GT4point6
Feb 8, 2020 12:49 PM
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
hndacr
Mar 25, 2011 12:18 PM
t_b
Dec 30, 2005 03:16 PM
