03 6.0 Powerstoke issues
Old Jul 30, 2024 | 10:03 AM
Yessianhnevala02's Avatar
Yessianhnevala02
4th Gear
I have a 2003 6.0 at low speeds or from a takeoff. It just has no power, it pretty much crawls from a dead stop until you put your foot into it. You hear the turbo spoil it after 2 or 3 seconds it launches. And then between 45 and 65 miles an hour it shakes very aggressively but doesn’t stall. But the top speeds it runs great has complete power and no further issues. The truck also dumps tons of black smoke at all speeds. Also, the truck takes forever to start, and after starting it dumps out a bunch of white and gray smoke.The truck is still all completely stock still has EGR, Doesn’t throw any codes and I have done a buzz test on the injectors and they all buzz very strong. I’m out here seeking a vice before digging into the truck or sending it to a shop.
Old Jul 30, 2024 | 08:18 PM
BLADE35's Avatar
BLADE35
Need to see live data to narrow down there’s a lot of possibilities this point
does it pass injector bubble test
supply side at KOEO and also cranking with wire looking at head supply lines upper fuel bowel
Any questions ^^just ask someone will be along shortly
any cac leaks
Old Jul 31, 2024 | 10:24 PM
Yessianhnevala02
4th Gear
So I have finally got some codes, I have a injector seven circuit code and a multiple misfire code, after pulling codes I did another buzz test and now number seven and one are both sticking
Old Aug 1, 2024 | 03:17 AM
Fuzzpuss's Avatar
Fuzzpuss
Time for some injectors. If you can swing it, replace all four on that side.
If you plan on replacing with rebuilt Motorcrafts, Fullforce Diesel is the place to go.
rtbrjason
May 21, 2021 09:13 AM
af11
Large Truck
May 26, 2014 11:53 AM
josh1991
May 20, 2012 04:15 PM
Gmcbuffalo
Aug 26, 2009 07:08 AM
