351W Questions
Old Jul 28, 2024 | 02:12 PM
oldF150XLT's Avatar
oldF150XLT
Trailering
Angry 351W Questions
I have a 1987 F150 with a 351 V8. The engine blew up, cracked a piston and a cylinder head. I bought some aluminum heads but need 'hardened' pushrods because the aluminum heads have guide plates. Any suggestions for pushrods that are not outrageously expensive?
Also, some sites are showing short pushrods for this thing, like are used for roller lifters, but the cam that was in it was a flat tappet hydraulic. Was that not an original cam?
For what it's worth, the truck is an '87 but the engine numbers indicate that it was made in 1986. It had a Holley 4V carb on it and the previous owner told me it was original.
Help?
Old Jul 28, 2024 | 02:19 PM
Conanski's Avatar
Conanski
Do the heads also have stud mount rockers? If so you can't use the OEM rockers.
You will need a pushrod length checker because standard length pushrods are not likely to be correct here. An '86 that came with a 4bbl could mean it was a 351HO, the cam in that motor was a flat tappet and was a pretty decent RV grind.
Old Jul 28, 2024 | 03:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by oldF150XLT
I bought some aluminum heads…the cam that was in it was a flat tappet hydraulic. For what it's worth, the truck is an '87 but the engine numbers indicate that it was made in 1986. It had a Holley 4V carb on it and the previous owner told me it was original.
What aluminum heads did you buy? What type of rocker arms? I agree with Conanski that you will need to measure for the correct pushrod length. The carburetor and a flat tappet is correct for an ‘87. The 351W didn’t get fuel injection until ‘88 and no roller camshaft until ‘94.
Old Jul 29, 2024 | 05:43 AM
manicmechanic007's Avatar
manicmechanic007
Well, the new aluminum heads were not fifty bucks right?
Get the expensive hardened pushrods they recommend
After measuring the length you need of course
Those heads should be set up with screw in studs and adjustable rockers
Means you will just use a fulcrum like a Boss 302 has with no rectangle at the bottom to go into the slot
If your existing rockers are stamped steel
You should be able to use them with Boss 302 fulcrums
Old Aug 1, 2024 | 03:27 PM
oldF150XLT's Avatar
oldF150XLT
Trailering
Thank you.
Old Aug 1, 2024 | 03:41 PM
My4Fordtrucks
Thank you.
Huh?
Are you not going to answer any of the questions we asked and figure it out on your own?
Old Aug 1, 2024 | 04:03 PM
oldF150XLT's Avatar
oldF150XLT
Trailering
Sorry. Had the flu the last few days. Not doing much computer sufing.
I got Summit Racing Pro Series Stainless Rocker Arms and FloTek heads
Probably not the greatest heads but don't have much to spend on this project. Got too many other things going on.
The short block is pretty much stock except the cam is CompCams High Energy 252H Hydraulic Flat Tappet Camshaft & Lifter Kit
At this moment it looks like I might not get around to putting things together for a couple months till I get the current project cleaned up, so can't measure the pushrod length yet.
I was looking for a little advice because I haven't worked on a Ford small block for about 30 years.
Thanks
Kawabuggy
27
Jun 10, 2023 02:46 PM
IHguy
18
Nov 24, 2017 09:11 PM
hail destroyer
Jul 27, 2017 10:07 PM
1bad67sbf
Apr 15, 2010 10:08 PM
f100guy
Sep 5, 2004 03:41 PM
